jan.koehler
Tue Apr 09, 2024 2:33 pm
Hi everyone,
I am trying to convert a via commandline tool with cfg File.
The Error in the log is
4/9 16:25:14.937 10e0 Facility ???ERROR: RunConsole: Invalid parameter does not finded out_file_type
but in the cfg file is
any idea why this error occurs?
Jan
jan.koehler
Wed Apr 10, 2024 12:45 pm
Hi Yaroslav
the complete command is
V2V_ConverterConsole.exe -c "c:\folder\server.cfg"
the cfg file:
in_host_type=win
in_host_address=hypervhost.com
in_host_username=hypervuser
in_host_password=hypervpass
in_file_name=X:\ClusterStorage\Volume\server\server_disk_1.vhdx
out_host_type=esx
out_host_address=esxhost.com
out_host_port=443
out_host_username=esxuser
out_host_password=esxpass
out_vm_name=server
out_file_name="[storage] folder\server_disk_1.vmdk"
out_file_type=ft_vmdk_esx_thin
Logfile (without first part where config is shown):
4/9 16:25:14.812 10e0 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.17763
4/9 16:25:14.812 10e0 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
4/9 16:25:14.812 10e0 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
4/9 16:25:14.812 10e0 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
4/9 16:25:14.812 10e0 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
4/9 16:25:14.812 10e0 Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
jan.koehler
Tue Apr 16, 2024 9:30 am
I updated to the newest version now and there is a difference in the filtypes compared to the docs found online.
File types:
ft_vhd_growable - MS VHD growable;
ft_vhd_pre_allocated - MS VHD pre-allocated;
ft_vhdx_growable - MS VHDX growable;
ft_vhdx_pre_allocated - MS VHDX pre-allocated;
ft_vmdk_ws_growable - VMDK growable for VMware Workstation;
ft_vmdk_ws_pre_allocated - VMDK pre-allocated for VMware Workstation;
ft_vmdk_esx_growable - VMDK growable for VMware ESXi Server;
ft_vmdk_esx_pre_allocated - VMDK pre-allocated for VMware ESXi Server;
ft_vmdk_so - VMDK stream-optimized;
ft_raw - RAW image;
ft_qcow2 - QCOW2 virtual disk;
ft_vdi_growable - VDI growable for Oracle VirtualBox;
ft_vdi_pre_allocated - VDI pre-allocated for Oracle VirtualBox.
so I changed to a support entry, but now I get another error Message in the logs:
4/16 10:58:32.811 25d8 Facility ???ERROR: RunConsole: VM VMNAME not found
The options are the same when I use the GUI tool, but with cli it is not working
jan.koehler
Tue Apr 16, 2024 11:37 am
only ASCII in the name, but it looks like the tool is putting a space in front of the VM name:
4/16 13:30:58.243 26b8 Facility ???ERROR: RunConsole: VM vmtest not found
It is the same result with config file or putting everything directly into the command line.
Tue Apr 16, 2024 11:55 am
Thanks for pointing that out. Can you run an individual command for one VM to see if we are dealing with syntax or V2V converter problems? thanks.
jan.koehler
Wed Apr 24, 2024 11:08 am
still not working, Error Message Remains the same
4/24 13:02:57.690 2408 Facility ???ERROR: RunConsole: VM vmtest not found
this refers directly to this line in the config File
