Error Connection to Azure
sashti
Thu Mar 21, 2024 10:43 am
I'm Getting the below error message when connecting to azure to get the subscription details. I am trying it on a Windows server 2012. Please help me on urgent basis. Thanks in advance.
Screenshot 2024-03-21 160805.png (45.43 KiB) Viewed 11777 times
Thu Mar 21, 2024 11:08 am
It looks like the Azure side is not set up correctly or there are firewall restrictions in your network/Azure side restrictions.
See how to set up the Azure side for the setup
https://www.starwindsoftware.com/v2v-he ... Azure.html
sashti
Thu Mar 21, 2024 12:21 pm
yaroslav (staff) wrote: ↑
I have used the same App registration for different server it's working fine and i have also turned off windows firewall. This server with this issue is hosted in IBM Cloud and does have any kind of firewall.
Thu Mar 21, 2024 4:04 pm
Can you please let me know what is the conversion scenario?
Are you trying p2v the servers to Azure? Also, if it worked for other servers, there might be something with that box.
sashti
Fri Mar 22, 2024 8:54 am
I am Trying P2V and it has worked for other server buut only for this server i am getting this error.
Fri Mar 22, 2024 9:09 am
There might be something funny on the network side of the setup.
samantha
Sat Apr 27, 2024 7:00 am
You can try pinging a public Microsoft server like `ping ping.microsoft.com` to see if there are any general network connectivity problems.
Sat Apr 27, 2024 7:58 am
Ping is quite a high-level test. It will just answer if there can be connectivity.
