vSphere OnPrem to vSphere on AWS cloud Fails
vayala1781
Wed Mar 06, 2024 6:34 pm
Hi team
This is my architecture.
VMWare vSphere 5.5 on-premise ESXi host with 25 VMs
VMWare vSphere 8.0 on AWS Cloud ESXi host supporting production.
I want to migrate those 25 vms from on-prem to AWS cloud using starwind converter.
I´m able to list the 25 vms, to list the ESX host in the AWS cloud but when the converter starts to work it fails with the following message.
Started
Converting virtual machine......
Success
Opening image file [xxxxxxxxx] VM-NAME
Success
Creating image file
Error creating image
A file was not found
Conversion failed
When I check in my VMC on AWS the VM is created but is not functional.
Any ideas for solving this issue?
starwind error.JPG (37.87 KiB) Viewed 11918 times
Wed Mar 06, 2024 7:10 pm
Greetings,
Thank you for your question. Could you please share the conversion logs from C:\Program Files\StarWind Software\StarWind V2V Converter\logs.
vayala1781
Wed Mar 06, 2024 10:32 pm
The log file name: 'logs\V2V_Log-20240304-135500.log' (PID 97228)
3/4 13:55:00.557 17790 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
3/4 13:55:00.558 17790 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.413
3/4 13:55:00.562 17790 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
3/4 13:55:00.562 17790 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
3/4 13:55:00.567 17790 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
3/4 13:55:00.573 17790 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ca5a0000
3/4 13:55:00.574 17790 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ca5a0000
3/4 13:55:05.540 17790 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
3/4 13:55:29.433 17790 Facility ???INFO: WrapperESXI::connect: m_url - https://15.10.154.25/sdk
3/4 13:55:29.627 17790 Facility ???INFO: WrapperESXI::connect: fullName - Administrator , key - 52ce7f0f-5c95-8fc5-7b40-95f9307c0c00
3/4 13:55:29.628 17790 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
3/4 13:55:29.843 17790 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:55:29.843 17790 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:55:29.843 17790 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:55:29.847 17790 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:55:29.847 17790 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:55:29.847 17790 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:55:30.101 17790 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:55:30.101 17790 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:55:30.101 17790 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:55:30.108 17790 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:55:30.109 17790 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:55:30.109 17790 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:55:30.152 17790 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:55:30.152 17790 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:55:30.152 17790 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:55:30.159 17790 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:55:30.159 17790 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:55:30.159 17790 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:55:30.163 17790 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:55:30.163 17790 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:55:30.163 17790 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:55:30.301 17790 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.5.0
3/4 13:56:20.518 17790 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
3/4 13:56:23.380 17790 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsAWS
3/4 13:57:58.728 17790 Facility ???INFO: WrapperESXI::connect: m_url - https://10.105.14.4/sdk
3/4 13:57:58.776 17790 Facility ???INFO: WrapperESXI::connect: fullName - cloudadmin , key - 52564c63-2bae-91bc-e91c-f916ef0d64e8
3/4 13:57:58.777 17790 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eSelectFolder
3/4 13:57:58.839 17790 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.0
3/4 13:57:58.840 17790 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.0
3/4 13:58:37.242 17790 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
3/4 13:58:37.256 d6c4 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 6
3/4 13:58:37.580 d6c4 Facility ???INFO: WrapperESXI::Wait: Progress - 5
3/4 13:58:37.582 d6c4 Facility ???INFO: WrapperESXI::Wait: Progress - 6
3/4 13:58:38.049 d6c4 Facility ???INFO: WrapperESXI::Wait: Progress - 10
3/4 13:58:38.066 d6c4 Facility ???INFO: WrapperESXI::Wait: Progress - 15
3/4 13:58:38.118 d6c4 Facility ???INFO: WrapperESXI::Wait: Progress - 25
3/4 13:58:38.374 d6c4 Facility ???INFO: WrapperESXI::Wait: Progress - 99
3/4 13:58:39.017 d6c4 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-140274
3/4 13:58:39.017 d6c4 Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-140274
3/4 13:58:44.404 d6c4 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [IBM-CONDESAPROD-04] SBC-ZSCALER-01/SBC-ZSCALER-01.vmdk, pathOutput: [WorkloadDatastore] SBC-ZSCALER-01/SBC-ZSCALER-01.vmdk
3/4 13:58:44.504 d6c4 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [IBM-CONDESAPROD-04] SBC-ZSCALER-01/SBC-ZSCALER-01.vmdk
3/4 13:58:44.504 d6c4 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-10099
3/4 13:58:44.520 d6c4 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 49:0F:C8:B8:86:2A:A0:79:ED:E4:78:F9:A2:5B:8B:59:7E:19:AA:AB
3/4 13:58:48.240 d6c4 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
3/4 13:58:51.258 d6c4 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [WorkloadDatastore] SBC-ZSCALER-01/SBC-ZSCALER-01.vmdk
3/4 13:58:51.258 d6c4 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-140274
3/4 13:58:51.271 d6c4 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 08:62:AE:94:42:DF:52:D3:CA:BB:79:F3:FE:EC:4B:D6:CD:4F:67:42
3/4 13:58:51.496 d6c4 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 4, A file was not found
3/4 13:58:51.496 d6c4 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
3/4 13:58:51.496 d6c4 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 1
3/4 13:58:51.590 d6c4 Facility ???ERROR: CPPConverting::Convert: FAILED
3/4 14:00:29.629 178bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
3/4 14:02:58.789 17a30 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
3/4 14:20:29.634 178bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
3/4 14:22:58.786 17a30 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
3/4 14:40:29.671 178bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
3/4 15:00:29.687 178bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
3/4 15:20:29.692 178bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
3/4 15:40:29.777 178bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
3/4 16:00:29.803 178bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
3/6 13:04:59.413 17790 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
3/6 13:04:59.422 17790 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
3/6 13:04:59.801 17790 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
3/6 13:04:59.801 17790 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
vayala1781
Wed Mar 06, 2024 10:33 pm
The log file name: 'logs\V2V_Log-20240304-134936.log' (PID 97152)
3/4 13:49:36.887 17b84 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
3/4 13:49:36.887 17b84 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.413
3/4 13:49:36.892 17b84 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
3/4 13:49:36.892 17b84 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
3/4 13:49:36.901 17b84 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
3/4 13:49:36.909 17b84 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ca5a0000
3/4 13:49:48.183 17b84 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
3/4 13:50:19.888 17b84 Facility ???INFO: WrapperESXI::connect: m_url - https://15.10.154.25/sdk
3/4 13:50:20.102 17b84 Facility ???INFO: WrapperESXI::connect: fullName - Administrator , key - 52a84b94-515c-a372-2386-b164c554d1e2
3/4 13:50:20.102 17b84 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
3/4 13:50:20.288 17b84 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:50:20.288 17b84 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:50:20.288 17b84 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:50:20.292 17b84 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:50:20.292 17b84 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:50:20.292 17b84 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:50:20.534 17b84 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:50:20.534 17b84 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:50:20.534 17b84 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:50:20.541 17b84 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:50:20.542 17b84 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:50:20.542 17b84 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:50:20.583 17b84 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:50:20.583 17b84 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:50:20.583 17b84 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:50:20.591 17b84 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:50:20.591 17b84 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:50:20.591 17b84 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:50:20.595 17b84 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/4 13:50:20.595 17b84 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/4 13:50:20.595 17b84 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/4 13:50:20.735 17b84 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.5.0
3/4 13:50:47.821 17b84 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
3/4 13:50:52.631 17b84 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsAWS
3/4 13:51:18.748 17b84 Facility ???INFO: WrapperESXI::connect: m_url - https://10.105.14.4/sdk
3/4 13:51:18.796 17b84 Facility ???INFO: WrapperESXI::connect: fullName - cloudadmin , key - 525a0ad5-8186-7ba3-7d03-444334094abe
3/4 13:51:18.797 17b84 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eSelectFolder
3/4 13:51:18.864 17b84 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.0
3/4 13:51:48.578 17b84 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
3/4 13:51:48.583 178ec Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 6
3/4 13:51:48.948 178ec Facility ???INFO: WrapperESXI::Wait: Progress - 5
3/4 13:51:48.950 178ec Facility ???INFO: WrapperESXI::Wait: Progress - 6
3/4 13:51:49.461 178ec Facility ???INFO: WrapperESXI::Wait: Progress - 10
3/4 13:51:49.477 178ec Facility ???INFO: WrapperESXI::Wait: Progress - 15
3/4 13:51:49.526 178ec Facility ???INFO: WrapperESXI::Wait: Progress - 25
3/4 13:51:49.786 178ec Facility ???INFO: WrapperESXI::Wait: Progress - 99
3/4 13:51:50.425 178ec Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-140273
3/4 13:51:50.425 178ec Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-140273
3/4 13:51:55.485 178ec Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [IBM-CNS-LUN-01] SBN-ZSCALER-02/SBN-ZSCALER-02.vmdk, pathOutput: [WorkloadDatastore] SBN-ZSCALER-02_TEST/SBN-ZSCALER-02.vmdk
3/4 13:51:55.685 178ec Facility ???INFO: ESXVmdk::ParseFile: sFilename - [IBM-CNS-LUN-01] SBN-ZSCALER-02/SBN-ZSCALER-02.vmdk
3/4 13:51:55.686 178ec Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-10117
3/4 13:51:55.698 178ec Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 49:0F:C8:B8:86:2A:A0:79:ED:E4:78:F9:A2:5B:8B:59:7E:19:AA:AB
3/4 13:51:59.704 178ec Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
3/4 13:52:03.061 178ec Facility ???INFO: ESXVmdk::ParseFile: sFilename - [WorkloadDatastore] SBN-ZSCALER-02_TEST/SBN-ZSCALER-02.vmdk
3/4 13:52:03.061 178ec Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-140273
3/4 13:52:03.073 178ec Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 08:62:AE:94:42:DF:52:D3:CA:BB:79:F3:FE:EC:4B:D6:CD:4F:67:42
3/4 13:52:03.262 178ec Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 4, A file was not found
3/4 13:52:03.262 178ec Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
3/4 13:52:03.262 178ec Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 1
3/4 13:52:03.371 178ec Facility ???ERROR: CPPConverting::Convert: FAILED
3/4 13:52:25.379 176ac Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
3/4 13:52:25.410 1771c Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
Fri Mar 08, 2024 7:01 pm
I will look into the logs.
Tue Mar 12, 2024 10:27 pm
Sorry for the delay. I have escalated these logs to R&D.
To me, it looks like there is something with connectivity to the ESXi inside AWS (maybe lacking some permissions). I would like my colleagues to help me with those. I will keep you posted.
Are any of these ESXi hosts Free?
vayala1781
Wed Mar 13, 2024 5:17 pm
Thanks for your help, NO those are not FREE ESXi host.
Wed Mar 13, 2024 5:56 pm
Thanks! I will keep you posted.
Fri Mar 15, 2024 4:31 pm
Thanks for your patience!
My colleague built a model setup and everything was working just well. We looked into the logs you shared and noticed that there might be privilege or connectivity issues. Make sure your use account has Virtual machine.Inventory.Create new and Virtual machine.Configuration.Add new disk privileges. See more at https://docs.vmware.com/en/VMware-Cloud ... 875C3.html.
