Error opening file
lucybc81
Tue Mar 05, 2024 1:02 pm
Hi everyone!
I'm trying to convert from a virtual machine .vmdk to hyper-v but, when I select it, the message is the next one:
error opening file (2) 0 disk encoding error.
I have read that this error has happened previously but I tried the different solutions and nothing happened. I tried to execute it as administrator, the vm is powered off...
Tue Mar 05, 2024 1:34 pm
Can you please check if there are any snapshots for that disk? Please also make sure the converter is run as administrator.
BrandynKunde
Fri Dec 06, 2024 1:59 am
Verify File Integrity: Ensure the .vmdk is not corrupted.
Convert with Third-Party Tools: Use software like qemu-img to convert the .vmdk to .vhdx.
Check Disk Type: Ensure the .vmdk is a supported type (e.g., monolithic or flat).
Permissions: Confirm you have full permissions and run as administrator
MichaelStephens
Fri Dec 06, 2024 4:34 am
I have the same error as you and I still haven't solved it.
