Tue Feb 27, 2024 11:41 am
Welcome to StarWind Forum
The software will do that for you. Yet, if you decide to convert individual disks, you will need to connect them to a VM afterward.
OnlyTryingtoLearn
Tue Feb 27, 2024 11:48 am
Hi Yaroslav
Thank you for the quick response and lastly i have seen posts that you have register the application, do i need to do that?
Tue Feb 27, 2024 12:25 pm
You are always welcome
This is done as a part of account preparation. Without it, conversion will not simply happen as the destination is not ready to act on the requests.
Cheers,
OnlyTryingtoLearn
Tue Feb 27, 2024 2:10 pm
Hi Yaroslav
Do you have any documentation on how to register the application or is that done at the time of "Enter the Azure Connection Parameters"
Thank you again
OnlyTryingtoLearn
Sun Mar 03, 2024 11:54 am
Hi
So I manage to start migrating the physical machine all was going well until i got an error message
Logs
3/2 0:53:20.740 3050 Facility ???ERROR: VMConverter::AzureConverter::CreateVM: CreateDisk Status code: 400 Error code: BadRequest Message: Changing property 'sourceUri' is not allowed for existing disk 'DataDisk_8723935427912920559'.
3/2 0:53:20.740 3050 Facility ???ERROR: CPPConverting::ConverterAzure: Create VM - Error sending request to Azure.
3/2 0:53:20.740 3050 Facility ???ERROR: CPPConverting::Convert: FAILED
Thanks again
Mon Mar 04, 2024 12:28 pm
That's strange. Thank you for your update.
The error code indicates an issue with the connection to Azure. Does your account have enough privileges to access all resources?
OnlyTryingtoLearn
Fri Mar 08, 2024 11:14 am
Hi
We followed the instructions provided, The App registration has contributor access to the subscription in Azure, The wizard did create a storage account and uploaded the converted VHD files but seem to fail when tring to create the virtual machine resource. Are we missing any permissions that are not included in the instructions.
OnlyTryingtoLearn
Mon Mar 11, 2024 9:51 am
Hi
Created a fresh account and the wizard did create a fresh storage account and uploaded the converted VHD files but seem to fail agian when tring to create the virtual machine resource.
Thanks again
Mon Mar 11, 2024 10:06 am
I think the Azure side of the setup is not configured correctly. It can also mean that Microsoft has changed again something on the Azure side so that new setups do not work well.
Please log a call with us at
support@starwind.com. Please use 1124292 and this thread as your references.
Gino23
Mon May 13, 2024 6:31 pm
I'm trying to migrate a physical machine to Azure.
At the new virutal machine settings I can't select an existing Network interface. Only option is to Create a new Network Interface.
