ESXI to Hyper-V Gen1 only
gaoyuanyyh
Thu Feb 22, 2024 2:04 am
when i want to do ESXI to Hyper-V convert. seems like only can convert to Gen1 version.
is this ture ?
Fri Feb 23, 2024 4:50 pm
It all depends on the boot option for the VM. EFI ones convert to Gen 2. Those with BIOS go to GEN1.
You can convert the disks separately and create the VM manually if such an automation does not work for you.
