StarWind Virtual SAN service to simulate a failover
dunkin45
Fri Feb 16, 2024 10:32 am
I'm doing a proof-of-concept in my lab with Virtual SAN Free. I ran the sample PowerShell script, and it successfully created the image and established the HA relationship. I connected my hosts to the iSCSI targets, moved a VM to the storage (using Failover Cluster and CSV). I then stopped the StarWind Virtual SAN service to simulate a failover. Everything is working as expected at this point.
After restarting the service, however, the nodes are not syncing. On the server that took over, the warning message says, "Partner Node is not ready, see Replication Manager for more details.". However, I can't use Replication Manager as I'm on the free edition.
On the node where I restarted the service, the warning message says "Non-active.".
Additionally, under Health Status, I have the following messages:
synchronization channel is down
heartbeat channel is down
partner is not synchronized
I've tried a number of PowerShell commands to try to force a sync but nothing is working.
10.0.1 1.0.0.01
Fri Feb 16, 2024 10:42 am
Check the IP addresses. Make sure you are using PRIVATE IPs.
atwell.greenaway
Mon Nov 04, 2024 10:12 pm
Private IP addresses are being used.
I am able to ping all IP addresses on the partner server.
Is there any way to force synchronization with the free version?
Tue Nov 05, 2024 8:14 am
Yes. See this thread viewtopic.php?p=34827#p34827
It will not work if you have a network issue.
