2/13 21:25:54.103663 1780 General: DllMain: NetDirect providers are not found.
2/13 21:25:54.103797 1780 Srv: *** iScsiServer::iScsiServer: iSER_DM is not loaded.- Intel E810-XXVDA2
- Broadcom BCM57416
I have tried so far:
- updating the network drivers to the latest version for each adapter
- I set up listeners in the config file
<iSerListen value="192.168.51.2,192.168.52.2,192.168.53.2,192.168.54.2,192.168.55.2,192.168.56.2"/> - installed NVM update for Intel adapters
- Set Network Direct Functionality to Enabled in the driver settings for all adapters
- Set all adapters to RoCEv2 in the "Network Direct Technology" driver settings. The default for Intel is iWARP.
- Ensured that Windows has enabled RDMA for all adapters (Enable-NetAdapterRdma -Name "*").
get-netadapterRdma Name InterfaceDescription Enabled PFC ETS ---- -------------------- ------- --- --- Ethernet 4 Intel(R) Ethernet Network Adapter E810-… True False True Ethernet 8 Intel(R) Ethernet Network Adapter E810-… True False True Ethernet 3 Supermicro 10GBASE-T Ethernet Controlle… True False True Ethernet 9 Intel(R) Ethernet Network Adapter E810-… True False True Ethernet 6 Intel(R) Ethernet Network Adapter E810-… True False True Ethernet 7 Intel(R) Ethernet Network Adapter E810-… True False True Ethernet 5 Intel(R) Ethernet Network Adapter E810-… True False True Ethernet 2 Supermicro 10GBASE-T Ethernet Controller True False True
