VSAN Variants
bertram
Sat Feb 10, 2024 8:56 am
Hi!
I'm looking for a brief description for your VSAN variants and their architecures. E.g. the release notes are mentioning OVF and CVM (OVF could be Open Virtualization Format but what is CVM?) versions with notes about Linux kernels updates while it's obvisiously that it can't be affect the "version that can be installed on a Windows host" (starwind-v8.exe, I can't even define it with an exact term :/ ).
I wonder if I'm the only one who feels this way. :/
Regards
betram
Thu Feb 15, 2024 8:51 am
StarWind Update has a standard procedure (https://knowledgebase.starwindsoftware. ... d-version/) that if done right and non-StarWind components work well, should not cause an issue.
