Create virtual Appliance on Hyper-V
chussi46359
Fri Feb 02, 2024 11:05 am
[*]Hey, today it´s my first setup for the free version. Using Server 2022 Standard Edition
I setup a hyper-v enviroment according to this guide:
https://www.starwindsoftware.com/resour ... chine-cvm/
I downloaded the VSAN CVM image and extracted the vhdx file.
I created the the VM in Gen2 and attached the existing disk. But the virtual machine will not start at all.
When I import the complete maschine, which I downloaded - the created machine is Gen1.
Any ideas what to do ? Leave Gen1 ?
Chris
Fri Feb 02, 2024 11:42 am
Greetings Chris,
Welcome to StarWind Forum! Yes, please leave it GEN1.
chussi46359
Fri Feb 02, 2024 11:44 am
So, I will not create my own virtual machine in hyper-v and use the complete downloaded version - or should I create a new vm and just select Gen1 ?
Fri Feb 02, 2024 12:05 pm
HI,
You can use the template and GEN1 as is. That is the intended way of using it, I believe. Also, we might improve the VM as the GEN2.
P.S. You can also try bare-metal version (or just use that one as the console) https://starwind.com/tmplink/starwind-v8.exe
