the disc image file is corrupted - vSphere 6 to Hyper-V
nrothwell
Thu Dec 07, 2023 7:02 pm
Migrating from vSphere 6 to Hyper-V cluster
tested the StarWind V2V Converter / P2V Migrator over VPN to a remote site with Hyper V cluster
using the remote function on the app I successfully converted a vSphere VM to Hyper V, however, I keep getting the disc image file is corrupted.
corrupted disk image - server 2012.png (175.1 KiB) Viewed 12021 times
corrupted disk image - server 2012-2.png (85.48 KiB) Viewed 12021 times
StarWind V2V Converter / P2V Migrator is installed on a Server 2022 Datacenter
is the app support on the server 2022 or am i missing something here
we need to move 200 vSphere VMs to Hyper V - do you have another product
thanks for the help
Thu Dec 07, 2023 10:00 pm
Welcome to StarWind Forum!
Is the disk actually doing well and does the VM start?
Can you please try converting an individual disk? Also, can you please convert it to a local file (i.e., VMDK to VHDX but as a local file)?
To automate conversion, you can try using CLI. I will file the feature request fro bulk VM conversion.
nrothwell
Thu Dec 07, 2023 11:02 pm
thanks for the reply
the app is installed on server 2022 Data Centre, I tried the individual disk to, the local file, and I noticed about halfway through that it went from say 45% to 100% and said completed
seems as it skipped 60% of the Disk and did not complete at all
Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
logs from last test
The log file name: 'logs\V2V_Log-20231207-230350.log' (PID 12448)
12/7 23:03:50.281 3360 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
12/7 23:03:50.281 3360 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.369
12/7 23:03:50.284 3360 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
12/7 23:03:50.284 3360 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
12/7 23:03:50.286 3360 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
12/7 23:03:50.295 3360 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - f9a40000
12/7 23:03:57.778 3360 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnection
12/7 23:04:00.674 3360 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
12/7 23:04:04.579 3360 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
12/7 23:04:21.399 3360 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.6.200/sdk
12/7 23:04:21.571 3360 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 524f8e20-088f-df35-24e0-3ea3b1c2dcbd
12/7 23:04:21.571 3360 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
12/7 23:04:23.034 3360 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.0.0
12/7 23:04:45.605 3360 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
12/7 23:04:53.922 3360 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsAzure
12/7 23:04:56.473 3360 Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
12/7 23:04:56.546 3360 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.20348
12/7 23:04:56.546 3360 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
12/7 23:06:04.666 3360 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
12/7 23:06:04.674 2b84 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
12/7 23:06:04.674 2b84 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Archive_VMs] LGCSBDC301 - Domain Controller/LGCSBDC301 - Domain Controller.vmdk, pathOutput: C:\ClusterStorage\Volume1\Hyper-V\Virtual Hard Disks\LGCSBDC301 - Domain Controller\Virtual Hard Disks\LGCSBDC301 - Domain Controlle.vhdx
12/7 23:06:05.185 2b84 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Archive_VMs] LGCSBDC301 - Domain Controller/LGCSBDC301 - Domain Controller.vmdk
12/7 23:06:05.185 2b84 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-118
12/7 23:06:05.201 2b84 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - FE:4A:26:7D:6B:CA:B9:E3:E1:29:CA:FC:13:73:D3:0D:EE:69:3E:5D
12/7 23:06:07.622 2b84 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
12/7 23:06:08.622 2b84 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 0
12/7 23:09:21.565 1868 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
12/7 23:26:24.475 2b84 Facility ???INFO: CPPConverting::ConvertImage: Success
12/7 23:26:24.475 2b84 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Archive_VMs] LGCSBDC301 - Domain Controller/LGCSBDC301 - Domain Controller_1.vmdk, pathOutput: C:\ClusterStorage\Volume1\Hyper-V\Virtual Hard Disks\LGCSBDC301 - Domain Controller\Virtual Hard Disks\LGCSBDC301 - Domain Controller_.vhdx
12/7 23:26:24.475 2b84 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Archive_VMs] LGCSBDC301 - Domain Controller/LGCSBDC301 - Domain Controller_1.vmdk
12/7 23:26:24.475 2b84 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-118
12/7 23:26:24.487 2b84 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - FE:4A:26:7D:6B:CA:B9:E3:E1:29:CA:FC:13:73:D3:0D:EE:69:3E:5D
12/7 23:26:25.602 2b84 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
12/7 23:26:26.357 2b84 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 0
12/7 23:37:35.612 2b84 Facility ???INFO: CPPConverting::ConvertImage: Success
12/7 23:37:36.103 2b84 Facility ???INFO: WrapperHyperV::modify_cpu_and_memory: MaxCPU - 32
12/7 23:37:36.128 2b84 Facility ???INFO: WrapperHyperV::getMaxMemory: MaxRAM - 511992
12/7 23:37:36.379 2b84 Facility ???INFO: VMConverter::HyperVConverter::CreateVM: add_disk_synthetic 1
12/7 23:37:36.545 2b84 Facility ???INFO: VMConverter::HyperVConverter::CreateVM: add_disk_synthetic 1
12/7 23:37:36.573 2b84 Facility ???INFO: CPPConverting::ConverterVMtoVM: Create VM 08A45BA6-4C8E-4738-963C-543744E51369
12/7 23:37:36.573 2b84 Facility ???INFO: CPPConverting::Convert: SUCCESSFULLY
12/7 23:50:03.418 3360 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
12/7 23:50:03.418 3360 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
Fri Dec 08, 2023 7:53 am
Thanks a lot! Can you please try converting the disk alone? Also, can you please see if it has any checkpoints and whether other disks can convert well?
nrothwell
Fri Dec 08, 2023 10:46 am
so i installed the app on the vSphere manager server 6.0
connected to remote VMware Cluster - converted to local file C: drive.
see below - we took over the client - the two hosts are up 7.5 years and vshphere has not been updated in 6 years
The log file name: 'logs\V2V_Log-20231208-102807.log' (PID 90352)
12/8 10:28:07.237 17328 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
12/8 10:28:07.237 17328 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.369
12/8 10:28:07.243 17328 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
12/8 10:28:07.243 17328 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
12/8 10:28:07.245 17328 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
12/8 10:28:07.248 17328 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 14120000
12/8 10:28:07.249 17328 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 14120000
12/8 10:28:11.236 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
12/8 10:28:36.647 17328 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.6.200/sdk
12/8 10:28:36.693 17328 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 52e48bde-a2f0-cbb8-3e91-0ba8bb159e63
12/8 10:28:36.694 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
12/8 10:28:37.538 17328 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.0.0
12/8 10:28:46.766 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
12/8 10:28:56.733 17328 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eInputVM
12/8 10:29:09.746 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
12/8 10:29:12.784 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
12/8 10:29:16.831 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
12/8 10:29:20.901 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
12/8 10:29:30.392 17328 Facility ???INFO: CPPOutputFile::onNext: Out path: C:\temp\LGCSBDC301 - Domain Controller_1.vhdx, Out format 11
12/8 10:29:30.392 17328 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
12/8 10:29:30.408 15eac Facility ???INFO: CPPConverting::Convert: InConvertType: 5, OutConvertType: 4
12/8 10:29:30.409 15eac Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Archive_VMs] LGCSBDC301 - Domain Controller/LGCSBDC301 - Domain Controller_1.vmdk, pathOutput: C:\temp\LGCSBDC301 - Domain Controller_1.vhdx
12/8 10:29:30.820 15eac Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Archive_VMs] LGCSBDC301 - Domain Controller/LGCSBDC301 - Domain Controller_1.vmdk
12/8 10:29:30.820 15eac Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-118
12/8 10:29:30.829 15eac Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - FE:4A:26:7D:6B:CA:B9:E3:E1:29:CA:FC:13:73:D3:0D:EE:69:3E:5D
12/8 10:29:32.546 15eac Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
12/8 10:29:34.204 15eac Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 0
12/8 10:33:36.695 14d44 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
12/8 10:35:33.470 15eac Facility ???INFO: CPPConverting::ConvertImage: Success
12/8 10:35:33.471 15eac Facility ???INFO: CVHDXFile::Mount: sFilename - C:\temp\LGCSBDC301 - Domain Controller_1.vhdx
12/8 10:35:34.568 15eac Facility ???ERROR: CVHDXFile::Mount: OpenVirtualDisk is fail - 1392
12/8 10:35:34.574 15eac Facility ???ERROR: CVHDXFile::Mount: The file or directory is corrupted and unreadable.
12/8 10:35:34.577 15eac Facility ???INFO: CPPConverting::Convert: SUCCESSFULLY
Fri Dec 08, 2023 11:17 am
Can you try a different VM on another datastore please?
