Another Hyper-V to VMWare question
eopia
Wed Dec 06, 2023 6:29 pm
I got 12 hyper-v VM's on a physical host that I need to convert to VMWare. I was looking at using VMWare converter, but the VM's need to be powered off and there's no ETA given unless the job is ran. How does Starwind V2V compare. Will it convert while the VM's are online and do a delta when we are ready to cutover, or does it require them to be offline as well?
Wed Dec 06, 2023 9:47 pm
Welcome to StarWind Forum.
You can try converting a working VM.
dogwatchscornful
Mon Jan 08, 2024 4:37 pm
A functional virtual machine can be converted.
tsaso90
Wed Jan 31, 2024 2:16 am
I think that's not easy to do.
Wed Jan 31, 2024 7:43 am
No, it's a pretty much straightforward and documented process.
ryeconclude
Tue Mar 26, 2024 7:31 am
Is converting a working VM complicated? I am a new user.
Tue Mar 26, 2024 7:36 am
Welcome to StarWind Forum. Just follow the guides from here https://www.starwindsoftware.com/v2v-help/Concept.html
Thely1946
Mon Jun 09, 2025 4:26 am
StarWind V2V does support live conversion, so you can keep the VMs running and then do a final delta sync before cutover. It's generally smoother for minimal downtime compared to VMware Converter.
Mon Jun 09, 2025 8:37 am
You are right: Shutting down the VM is needed only if V2V cannot merge the snapshots.
Thely1946
Mon Jun 09, 2025 9:35 am
Got it, thanks for the clarification! I’ll make sure to try without shutting down first, and only power off if the snapshot merge fails.
Mon Jun 09, 2025 9:45 am
You are always welcome.
Thely1946
Tue Jun 10, 2025 8:43 am
Thank you
