Server 2022 Hyper-V- Free vSAN Setup Error
rfarhank
Tue Nov 21, 2023 1:27 pm
I am looking for support, I have been trying to setup 2 node Starwind vSan using the Free license via Powershell but seems to be running into multiple errors. I have tried to follow the guide provided but seems to be getting multiple errors. i.e.
Target name and Alias are empty
Error 200 Invalid Partner node info
I would really appreciate if anyone can help me with this. I have provided my amended script below:-
param($addr="192.168.80.55", $port=3261, $user="root", $password="starwind",
$addr2="192.168.80.56", $port2=$port, $user2=$user, $password2=$password,
#common
$initMethod="Clear",
$size=1200,
$sectorSize=512,
$failover=0,
$bmpType=1,
$bmpStrategy=0,
#primary node
$imagePath="My computer\D\starwind",
$imageName="masterImg21",
$createImage=$true,
$storageName="",
$targetAlias="targetha21",
$autoSynch=$true,
$poolName="pool1",
$syncSessionCount=1,
$aluaOptimized=$true,
$cacheMode="wb",
$cacheSize=128,
$syncInterface="#p2=172.16.10.20:3260" -f $addr2,
$hbInterface="#p2=172.16.20.20,192.168.80.56:3260" -f $addr2,
$createTarget=$true,
$bmpFolderPath="",
#secondary node
$imagePath2="My computer\D\starwind",
$imageName2="partnerImg22",
$createImage2= $true,
$storageName2="",
$targetAlias2="partnerha22",
$autoSynch2=$true,
$poolName2="pool1",
$syncSessionCount2=1,
$aluaOptimized2=$true,
$cacheMode2=$cacheMode,
$cacheSize2=$cacheSize,
$syncInterface2="#p1=172.16.10.10:3260" -f $addr,
$hbInterface2="#p1=172.16.20.10:3260,192.168.80.55:3260" -f $addr2,
$createTarget2=$true,
$bmpFolderPath2=""
Import-Module StarWindX
try
$server.Connect()
$firstNode = new-Object Node
$firstNode.HostName = "localhost"
$firstNode.HostPort = "3261"
$firstNode.Login = "root"
$firstNode.Password = "starwind"
$firstNode.ImagePath = "My computer\D\starwind"
$firstNode.ImageName = "masterImg21"
$firstNode.Size = 2048
$firstNode.StorageName = ""
$firstNode.TargetAlias = "targetha21"
$firstNode.AutoSynch = $true
$firstNode.SyncInterface = "#p1=172.16.10.10:3260" -f $addr
$firstNode.HBInterface = "#p2=172.16.20.20,192.168.80.56:3260" -f $addr2
$firstNode.PoolName = "pool1"
$firstNode.CacheMode = "wb"
$firstNode.CacheSize = "128"
$firstNode.CreateTarget = $true
$firstNode.SectorSize = 4096
$secondNode = new-Object Node
$secondNode.HostName = "172.16.10.20"
$secondNode.HostPort = "3261"
$secondNode.Login = "root"
$secondNode.ImagePath = "My computer\D\starwind"
$secondNode.ImageName = "partnerImg22"
$secondNode.CreateImage = "$true
$secondNode.StorageName = ""
$secondNode.TargetAlias = "Partnerha22"
$secondNode.AutoSynch = $true
$secondNode.SyncInterface = "#p1=172.16.10.10:3260",
$secondNode.HBInterface = "#p1=172.16.20.10:3260,192.168.80.55:3260" -f $addr2
$secondNode.CacheMode = "none"
$secondNode.CacheSize = ""
$secondNode.CreateTarget = $true
Start-Sleep -m 2000
$device.Refresh()
catch
Write-Host $_ -foreground red
finally
$server.Disconnect()
Tue Nov 21, 2023 1:59 pm
Welcome to Starwind Forum and thanks for sharing your script. Use this script https://forums.starwindsoftware.com/vie ... p+3#p31505.
Alternatively, type a valid bitmap path or comment on all lines about bitmap.
rfarhank
Wed Nov 22, 2023 12:47 pm
Thanks Yarosluv for your prompt response.
As suggested I have commented all bitmap line, however I am still getting the error "Invalid Partner Info ", (Please see image attached for full error)
Invalid Partner info.png (141.92 KiB) Viewed 12318 times
However I have noticed in management console (monitoring only) that it has created an image file on Node 1 but not replicated on second node.
Starwind Managment console status.png (36.38 KiB) Viewed 12318 times
Please Advise, your help would be much appreciated.
See below my final script which I had used:-
try
$server.Connect()
$firstNode.ImageName = "masterImg30"
$firstNode.Size = 1024
$firstNode.TargetAlias = "targetha30"
$firstNode.SyncInterface = "#p2=172.16.10.20:3260"
$firstNode.PoolName = "Pool1"
$firstNode.CacheMode = ""
$firstNode.CacheSize = ""
$firstNode.BitmapStoreType = ""
$firstNode.BitmapStrategy = ""
$firstNode.BitmapFolderPath = ""
$secondNode.HostName = "192.168.80.56"
$secondNode.ImageName = "partnerImg30"
$secondNode.CreateImage = "$true"
$secondNode.TargetAlias = "Partnerha30"
$secondNode.HBInterface = "#p1=172.16.20.10,192.168.80.55:3260"
$secondNode.CacheMode = ""
$secondNode.BitmapFolderPath = ""
Start-Sleep -m 2000
$device.Refresh()
catch
finally
Wed Nov 22, 2023 1:45 pm
Thanks for your update. Could you please let me know if you had a chance to take the script I shared above and fit it into your system?
Will be waiting for your reply.
rfarhank
Wed Nov 22, 2023 2:09 pm
Hi
Yes, I also ran the script that was provided in the (viewtopic.php?f=5&t=5624&p=31505&hilit=tip+3#p31505) see below.
When I ran this script it didn't do anything - it didn't throw any error but also not processed anything - please see image below
Shared Script Update.png (177.26 KiB) Viewed 12312 times
Wed Nov 22, 2023 3:16 pm
Could you please clear out old entries from StarWind.cfg.
1. stop the service.
2. go to StarWind.cfg
3. locate <targets/> folder.
4. locate imagefiles.
5. remove the entries.
6. clear out the files from the underlying storage.
7. repeat for another server.
8. start StarWindService.
Also, try $initMethod="syncfromfirst" as described here https://forums.starwindsoftware.com/vie ... rst#p35005.
