j2hydro
Thu Nov 02, 2023 7:07 pm
Redhat has eol their RHV product, so looking to get my VMs over to the VMware world.
Export of disk from RHV to image file, then process via starwinds v2v convert into vmware.
first problem starwinds says does not support qcow3, but disk from qemu-img shows version qcow2.
VMware sees nothing, any tools, i dont see the disk intact.
- qcow2 image pre convert
- Screenshot 2023-11-02 140238.png (17.42 KiB) Viewed 57289 times
Tue Feb 27, 2024 1:40 pm
It's QCOW3 actually. This thing should work now, did you check the most recent version?
obisims
Mon Sep 09, 2024 3:37 am
I am a new member. I have encountered this error before and it is fixed in the latest version.
Thu Sep 12, 2024 12:31 pm
Thank you for your update!
obisims wrote: ↑Mon Sep 09, 2024 3:37 am
thiery
Thu Jul 24, 2025 2:56 pm
I had the same issue at step 6 turned out the volume names needed to be unique. Also had some network visibility problems between nodes. After fixing that and redeploying, everything worked fine.
Daniel Jackson
Fri Jul 25, 2025 4:40 am
I’m a new member too, and I’ve come across this error before — it’s already been fixed in the latest version, so updating should resolve it.
