Select OS disk empty and disabled on physical to Hyper-V
CPC
Thu Nov 02, 2023 11:44 am
Hello.
I need to migrate a physical Windows Server 2012R2 as a VM in a Hyper-V host running under Windows Server 2022 in the same LAN.
I run StarWind V2V converter (version 9.0.1.364) in the physical machine and follow the steps of the wizard.
1 - Select location of the image to convert: P2V
2 - Select physical data to convert: Entire machine
3 - Select disk volumes to convert: Both C;\ and \\?\Volume{3.... are selected
4 - Select the location of the destinarion image: Microsoft Hyper-V Server
5 - Enter Microsoft Hyper-V Server connection parameters:
Hostname: IP address of Hyper-V server on the LAN
Username and password: Credentials for administrator user on the Hyper-V server
6 - Here comes the problem:
Under Path virtual machine, I can select the destinarion partition on the Hyper-V machine
Rest of fields are filled, but field Select OS disk is empty and greyed out, disabled.
What am I doing wrong ?
Thank you in advance !
Empty and disabled "Select OS disk" field
Thu Nov 02, 2023 12:19 pm
Thank you for your question. May I wonder if conversion runs if you press Convert?
CPC
Thu Nov 02, 2023 12:58 pm
Hi.
Nothing seems to happen after clicking on Convert button.
The button is enabled, it gets the focus and responds to click event, but anything happens.
I can even click on it several times in a row ...
If I click on Cancel button it asks me if I want to cancel and just closes gracefuly.
Thu Nov 02, 2023 3:24 pm
Thanks for your swift reply and effort.
That's strange. Could you please try converting individual disks into VHD(X)?
