How to recover data from StarWind SAN&NAS
valerymartyshko
Wed Nov 01, 2023 12:42 pm
Hi! I need to recover data from a crashed RAID with StarWind SAN&NAS operating system. How to recover data from a RAID level 5 with the XFS file system?
Are there specific tools or methods recommended for data recovery from a virtual NAS like StarWind SAN&NAS?
Wed Nov 01, 2023 3:57 pm
Sorry to read that. Could you please tell me more about the issue and how exactly you ended up with corrupted data?
Also, how does the corruption of data manifest itself? Are those the VMs who cannot start or anything like that?
valerymartyshko
Thu Nov 02, 2023 7:01 am
yaroslav (staff) wrote:Hi,
yes it is, the virtual machine does not start. At some point, it simply stopped loading.
By the way, I have already found some programs that can read damaged disks of virtual machines. I will test it now.
Thu Nov 02, 2023 3:29 pm
Thanks for your update.
Is it SAN and NAS VM or the client VM? If that's Starwind SAN & NAS VM, having a screenshot of the error will be helpful.
May I wonder what was done before the incident?
valerymartyshko
Fri Nov 03, 2023 2:47 pm
yaroslav (staff) wrote:Thanks for your update.
It is a client VM (VMWare).
The error appeared after the equipment was turned off, as a result of a power failure.
StarWind VM Error
StarWind VM Error
Fri Nov 03, 2023 5:08 pm
Correct me if I am reading it wrong. You have an issue with booting a StarWind SAN & NAS VM, not the client VM.
It looks like you got a snapshot corrupted, meaning that the issue is to be addressed on the virtualization layer (i.e., outside the SAN & NAS world). Can you please try changing the config to read from the bulk virtual machine disk, not from the checkpoint (beware of data loss).
valerymartyshko
Mon Nov 06, 2023 7:00 am
Please let me know how I can do this. I didn't quite understand
Mon Nov 06, 2023 7:21 am
Please note that this case falls under hypervisor behaviors trouleshooting.
What hypervisor you use?
valerymartyshko
Mon Nov 06, 2023 10:03 am
VMWare
valerymartyshko
Mon Nov 06, 2023 10:26 am
I came across an article about data recovery from StarWind SAN&NAS. In it, data was restored using the program - Hetman RAID Recovery. I downloaded and mounted the disk of my idle virtual machine to it. Program read it and displayed my data.
If you help restore the virtual machine, I will be grateful. If it doesn't work, then I will restore the data with this program.
Last edited by valerymartyshko on Wed Nov 08, 2023 8:22 am, edited 1 time in total.
Mon Nov 06, 2023 12:43 pm
I think the easiest way will be restoring data with the third-party app you mentioned.
