V2V issues
arjun
Wed Oct 18, 2023 5:37 am
I am trying to V2V a windows VM to VMware platform where the vCenter is remote and there is firewall between the source VM and the local destination ESX server. Below are the logs:-- Please suggest some solution to enable this V2V.
The log file name: 'logs\V2V_Log-20231018-071000.log' (PID 18868)
10/18 7:10:00.268 4370 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
10/18 7:10:00.268 4370 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
10/18 7:10:00.283 4370 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
10/18 7:10:00.283 4370 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
10/18 7:10:00.283 4370 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
10/18 7:10:00.283 4370 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - c6d00000
10/18 7:10:05.877 4370 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
10/18 7:10:09.721 4370 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
10/18 7:10:11.471 4370 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
10/18 7:10:14.330 4370 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
10/18 7:10:41.049 4370 Facility ???INFO: WrapperESXI::connect: m_url - https://10.31.200.36/sdk
10/18 7:11:02.080 4370 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
10/18 7:11:02.080 4370 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
"A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Detail: connect failed in tcp_connect()
10/18 7:11:02.080 4370 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
10/18 7:11:08.080 4370 Facility ???WARNING: CPPESXConnectionTo::onNext: connect A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10/18 7:11:22.971 4370 Facility ???INFO: WrapperESXI::connect: m_url - https://10.31.200.36/sdk
10/18 7:11:44.002 4370 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
10/18 7:11:44.002 4370 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
10/18 7:11:44.002 4370 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
10/18 7:20:58.705 4370 Facility ???WARNING: CPPESXConnectionTo::onNext: connect A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10/18 7:21:49.424 4370 Facility ???INFO: WrapperESXI::connect: m_url - https://10.145.36.101/sdk
10/18 7:21:49.815 4370 Facility ???INFO: WrapperESXI::connect: fullName - , key - 525431f0-16c8-2dec-d01a-065b84f61660
10/18 7:21:49.815 4370 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
10/18 7:21:52.299 4370 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
10/18 7:22:52.533 4370 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
10/18 7:22:52.549 4c58 Facility ???INFO: CPPConverting::Convert: InConvertType: 3, OutConvertType: 6
10/18 7:23:00.283 4c58 Facility ???INFO: CheckFileESX::CheckFileExistance: GetBrowser fail - File [OBE-Datastore-Vol01] MyPC was not found
10/18 7:23:15.893 4c58 Facility ???INFO: CheckFileESX::CheckFileExistance: GetBrowser fail - File [OBE-Datastore-Vol01] MyPC was not found
10/18 7:23:26.611 4c58 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-85888
10/18 7:23:26.611 4c58 Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-85888
10/18 7:23:42.986 4c58 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 0, pathOutput: [OBE-Datastore-Vol01] MyPC/HDD0.vmdk
10/18 7:23:42.986 4c58 Facility ???INFO: P2V::CreateInputImage: path 0
10/18 7:23:42.986 4c58 Facility ???INFO: P2V::CreateInputImage: Size 0 - 128849018880, BytesPerSector - 512
10/18 7:23:48.127 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
10/18 7:23:48.236 4c58 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [OBE-Datastore-Vol01] MyPC/HDD0.vmdk
10/18 7:23:48.236 4c58 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-85888
10/18 7:23:48.408 4c58 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 21:1F:25:E9:6E:9F:AA:C3:85:F8:EA:51:3E:2C:C8:F7:DA:C5:20:D1
10/18 7:23:49.986 4c58 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
10/18 7:23:49.986 4c58 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
10/18 7:23:49.986 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
10/18 7:23:49.986 4c58 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 1, pathOutput: [OBE-Datastore-Vol01] MyPC/HDD1.vmdk
10/18 7:23:49.986 4c58 Facility ???INFO: P2V::CreateInputImage: path 1
10/18 7:23:49.986 4c58 Facility ???INFO: P2V::CreateInputImage: Size 1 - 53687091200, BytesPerSector - 512
10/18 7:23:53.565 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
10/18 7:23:53.565 4c58 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [OBE-Datastore-Vol01] MyPC/HDD1.vmdk
10/18 7:23:53.565 4c58 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-85888
10/18 7:23:53.721 4c58 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 21:1F:25:E9:6E:9F:AA:C3:85:F8:EA:51:3E:2C:C8:F7:DA:C5:20:D1
10/18 7:23:55.049 4c58 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
10/18 7:23:55.049 4c58 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
10/18 7:23:55.049 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
10/18 7:23:55.049 4c58 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 2, pathOutput: [OBE-Datastore-Vol01] MyPC/HDD2.vmdk
10/18 7:23:55.049 4c58 Facility ???INFO: P2V::CreateInputImage: path 2
10/18 7:23:55.049 4c58 Facility ???INFO: P2V::CreateInputImage: Size 2 - 107374182400, BytesPerSector - 512
10/18 7:23:59.143 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
10/18 7:23:59.143 4c58 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [OBE-Datastore-Vol01] MyPC/HDD2.vmdk
10/18 7:23:59.143 4c58 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-85888
10/18 7:23:59.315 4c58 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 21:1F:25:E9:6E:9F:AA:C3:85:F8:EA:51:3E:2C:C8:F7:DA:C5:20:D1
10/18 7:24:00.611 4c58 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
10/18 7:24:00.611 4c58 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
10/18 7:24:00.611 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
10/18 7:24:00.611 4c58 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 3, pathOutput: [OBE-Datastore-Vol01] MyPC/HDD3.vmdk
10/18 7:24:00.611 4c58 Facility ???INFO: P2V::CreateInputImage: path 3
10/18 7:24:00.611 4c58 Facility ???INFO: P2V::CreateInputImage: Size 3 - 536870912000, BytesPerSector - 512
10/18 7:24:05.018 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
10/18 7:24:05.018 4c58 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [OBE-Datastore-Vol01] MyPC/HDD3.vmdk
10/18 7:24:05.018 4c58 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-85888
10/18 7:24:05.174 4c58 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 21:1F:25:E9:6E:9F:AA:C3:85:F8:EA:51:3E:2C:C8:F7:DA:C5:20:D1
10/18 7:24:06.533 4c58 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
10/18 7:24:06.533 4c58 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
10/18 7:24:06.533 4c58 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
10/18 7:24:06.533 4c58 Facility ???ERROR: CPPConverting::Convert: FAILED
Wed Oct 18, 2023 7:46 am
According to the logs
Firewall seems to be blocking connections.
arjun
Wed Oct 18, 2023 1:43 pm
Correct. Once Firewall issue was sorted out the conversion happened. You can close the thread.
Wed Oct 18, 2023 1:58 pm
Thanks for letting me know :)
