vCenter keeps showing certificate warning when register VASA
dell3
Sat Sep 30, 2023 1:53 pm
I am trying to build an VVol storage with Starwind vSAN. The binding has been done. The result of getVASAinfo:
instance of __PARAMETERS
ReturnValue = "Success";
serverCertificateHash = "444865XXXXXXXXXXXXXXXXXXXXXX39D5";
VASAUrl = "https://192.168.XXX.XXX:9991/vasa";
I tried to access the url in web browser. vasa.vasa file can be downloaded.
Then I tried to register the storage provider in vCenter 8.0. But the certificate warning keeps popping up. What should I do to get this registration done?
Thanks.
Sat Sep 30, 2023 5:42 pm
Could you let me know what happens if youpress "yes"?
Please look under troubleshooting section https://www.starwindsoftware.com/resour ... iew-guide/
dell3
Sun Oct 01, 2023 1:18 pm
Thanks for reply.
The article you provided was the one I followed. I click Yes, the warning showed up again. that's the problem.
dell3
Sun Oct 01, 2023 1:22 pm
Just FYI, I have tried this on 3 vCenter8.0 servers. one of them are newly installed. Same result.
Mon Oct 02, 2023 9:04 am
Were all of them vCenter 8?
dell3
Mon Oct 02, 2023 9:07 am
Today, I rebuilt the starwind cluster from scratch. I followed the guide step by step. But I still got the error (warning keeps showing).
Is starwind vSan's VASA working on VCSA8?
dell3
yep. all VCSA 8.0.
Mon Oct 02, 2023 3:03 pm
Just wanted to make sure that I understood your question correctly.
You were able to activate the VASA provider, but the certificate keeps popping up, am I reading it right?
Also, are you using StarWind VSAN for vSphere (i.e., a VM deployed from the OVF template), or a Windows-based installation?
dell3
Tue Oct 03, 2023 10:31 am
Actually I downloaded the vSphere version first. But I went back to Windows based installation since I was unable to find any guide for VVOL on Linux-based appliance. If there is any doc for Linux-based appliance building VVOL, please share it with me. I can have a try. Thanks.
Anyways, now I am using the excact some configuration in https://www.starwindsoftware.com/resour ... iew-guide/. And the problem is:
1. Add a new storage provider.
2. Type in the url, username. password.
3. Click OK.
4. The Security Alert shows up.
5. Click Yes.
6. A few seconds later, the same Security Alert shows up again.
7. Click Yes again. The same Security Alert shows up again again.
Dead end.
If I click No, it goes back to New Storage Provider page. Feels like VCSA does not accept the certificage Starwind's VASA is using.
John
Tue Oct 03, 2023 11:44 am
Thanks for your update! I will discuss this internally and get back to you.
Wed Oct 11, 2023 11:43 am
Greetings,
Sorry for the delay. Could you please share the logs from
C:\Program Files\StarWind Software\StarWind\StarWindCluster\Log
C:\Program Files\StarWind Software\StarWind\logs
dell3
Wed Oct 11, 2023 1:40 pm
I have uploaded the logs at https://drive.google.com/file/d/1pg8JNM ... sp=sharing.
There are 2 nodes as the guide. I run the commands on node 1 except the ones which were marked to run on node 2.
Thanks.
dariohill
Fri Oct 13, 2023 2:36 am
dell3 wrote:Hi,
Thanks.
Thanks for being so specific. pls
dell3
Tue Oct 17, 2023 7:52 am
Hi yaroslav.
Any update on the issue?
Thanks.
Tue Oct 17, 2023 9:33 am
My colleagues are still reviewing the logs. I will keep you posted.
