StarWind Software Update
kkit
Wed Sep 27, 2023 12:34 pm
I want to update my StarWind Software
Version V8 (build 15159)
To:
Version V8 (build 15260)
The Software is running with no problems at the moment, is it still recommended to upgrade to the latest version?
Changelog says:
Fixed an issue with synchronization/heartbeat channels unable to restore the connection when performance degradation occurs on the underline storage and VAAI is enabled for StarWind HA Devices.
I did not activate VAAI, at least not knowingly.
Should I update?
Wed Sep 27, 2023 12:51 pm
You can update to the latest build. This fix applies to StarWind VSAN for vSphere deployments.
VAAI is on for VMFS datastores by default https://core.vmware.com/resource/vmware ... ation-vaai.
trapdoorremnant
Wed Oct 18, 2023 2:42 am
yaroslav (staff) wrote:You can update to the latest build. This fix applies to StarWind VSAN for vSphere deployments.
I can't access your link. I'm having the same problem.
Wed Oct 18, 2023 7:43 am
Strangely, worked for me. Try again.
