itworxbw
Wed Sep 20, 2023 8:23 am
Hi, I am trying to convert a server 2019 std VM running on 2019 Hyper-V box Config version 9 to qcow2, which will be running on Acronis Cyber Infrastructure compute. I tried this on an existing VM and imported and booted and got error with automatic windows repair option when trying to boot the qcow2. I decided to rule out possible issues with in use machine and built a fresh 2022 windows server standard and once again converted and attempted to boot and again I get automatic windows repair once again. Is there anything I could do different in convert to avoid error.
itworxbw
Fri Sep 22, 2023 12:38 pm
HI, thanks for the reply. I have tried to run P2V inside hyper-v VM and when i get to output, local file is greyed out and as such no option to choose Qcow2, see attachments. Thanks
- Step 2.png (109.08 KiB) Viewed 9740 times
- Step 1.png (147.92 KiB) Viewed 9740 times
