Old session with the same ID is still present.Login rejected
ljin
Tue Sep 19, 2023 7:35 am
I'm using vSAN Free with the latest version (StarWind Virtual Storage Appliance v8.0.0 (Build 15260, [SwVSA], Win64) )
So far, I'm not using replicated SAN storage because of some occasional reliability issues, instead I'm just using a plain local, non synchronized, NAS image to build a large datastore for backup purpose.
It was working fine, but a few days ago, after updating vSphere with the latest patches, after reboot, I'm getting frenquently (every few hours) those warnings in Starwind logs (each time I get 6 of them within a minute):
"Old session with the same ID is still present. Login rejected! Please try to reconnect Initiator."
More detailed logs when this occur:
9/19 7:24:01.463632 33 IMG: *** ImageFile_ScsiExec: SCSIOP (0x85) is not supported.
9/19 7:29:09.269444 7a IMG: ImageFile_IoCompleted: Warning(Time FileIO): request(0x0000000003024CA0) ssc(0x0000000003242948) function(Execute SCSI Command) opCode(0x8A), timeFileIO = 5229 ms, g_cmdE
ecTimeWarningLimitInSec = 3 s. Device: 'C:\StarWind\storage\mnt\NVMe\nas110\nas110.img'
9/19 7:29:09.269591 7a IMG: ImageFile_ScsiCompleteRequest: Warning(Time Request EXEC): request(0x0000000003024CA0) ssc(0x0000000003242948) function(Execute SCSI Command) opCode(0x8A), timeExecReques
= 5229 ms, g_cmdExecTimeWarningLimitInSec = 3 s. Device: 'C:\StarWind\storage\mnt\NVMe\nas110\nas110.img'
9/19 7:29:09.269613 7a IMG: ImageFile_ScsiCompleteRequest: Warning(Time Request EXEC): request(0x0000000003026F90) ssc(0x000000000181BE00) function(Execute SCSI Command) opCode(0x8A), timeExecReques
9/19 7:29:09.269875 7a IMG: ImageFile_IoCompleted: Warning(Time FileIO): request(0x0000000003023D30) ssc(0x0000000003244D08) function(Execute SCSI Command) opCode(0x8A), timeFileIO = 3749 ms, g_cmdE
9/19 7:29:09.269894 7a IMG: ImageFile_ScsiCompleteRequest: Warning(Time Request EXEC): request(0x0000000003023D30) ssc(0x0000000003244D08) function(Execute SCSI Command) opCode(0x8A), timeExecReques
= 3749 ms, g_cmdExecTimeWarningLimitInSec = 3 s. Device: 'C:\StarWind\storage\mnt\NVMe\nas110\nas110.img'
9/19 7:29:09.269915 7a IMG: ImageFile_ScsiCompleteRequest: Warning(Time Request EXEC): request(0x00000000030291B0) ssc(0x000000000300F8C0) function(Execute SCSI Command) opCode(0x2A), timeExecReques
9/19 7:33:07.534675 100 T[1c,14c8dc]: iScsiTask::handleTaskMgmtCmd: Management command: abort task (CmdSN 26857391, ITT 0xe3cf9901) not found.
9/19 7:33:17.536294 100 T[1c,14c8de]: iScsiTask::handleTaskMgmtCmd: Management command: abort task (CmdSN 26857391, ITT 0xe3cf9901) not found.
9/19 7:33:23.485453 100 C[1c], LIN: iScsiConnection::recvData: Recv - peer shutdown
9/19 7:33:23.485527 100 C[1c], LIN: iScsiConnection::receive: recvData returned error 10058 (0x274a)!
9/19 7:33:23.486329 100 C[1c], LIN: iScsiConnection::recvWorker: *** 'recv' thread: recv failed 10058.
9/19 7:33:23.487119 101 Srv: *** SwSocket::Shutdown: shutdown() failed with error 10058!
9/19 7:33:23.487345 101 Srv: *** SwSocket::Shutdown: shutdown() failed with error 10058!
9/19 7:33:26.016227 9 Srv: iScsiServer::listenConnections: Accepted iSCSI connection from a.b.c.1:18272 to a.b.c.10:3260. (Id = 0x1d)
9/19 7:33:26.016299 9 S[1d]: iScsiSession::iScsiSession: Session (00000000010FA180)
9/19 7:33:26.016314 9 C[1d], FREE: iScsiConnection::doTransition: Event - CONNECTED.
9/19 7:33:26.266138 1db C[1d], XPT_UP: iScsiConnection::handleFirstLogin: Login request: ISID 0x00023d000001, TSIH 0x0000.
9/19 7:33:26.266221 1db C[1d], XPT_UP: iScsiConnection::doTransition: Event - LOGIN.
9/19 7:33:26.266296 1db Params: iScsiParameter::update: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:xxxxxxxxxxxxxxxxxxxxxxxxxxxx:1242115180:64', accepted 'iqn.1998-01.com.vmwar
9/19 7:33:26.266317 1db Params: iScsiParameter::update: <<< String param 'InitiatorAlias': received 'iscsi_vmk', accepted 'iscsi_vmk'
9/19 7:33:26.266346 1db Params: iScsiParameter::update: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.1.10-nas110', accepted 'iqn.2008-08.com.starwindsoftware:192
168.1.10-nas110'
9/19 7:33:26.266359 1db Params: iScsiParameter::update: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
9/19 7:33:26.266370 1db Params: iScsiParameter::update: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
9/19 7:33:26.266383 1db Params: iScsiParameter::update: <<< Enum param 'DataDigest': received 'None', accepted 'None'
9/19 7:33:26.266397 1db Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
9/19 7:33:26.266409 1db Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
9/19 7:33:26.266420 1db Params: iScsiParameter::update: <<< Boolean param 'IFMarker': received No, accepted 0
9/19 7:33:26.266434 1db Params: iScsiParameter::update: <<< Boolean param 'OFMarker': received No, accepted 0
9/19 7:33:26.266447 1db Params: iScsiParameter::update: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
9/19 7:33:26.266461 1db Params: iScsiParameter::update: <<< Boolean param 'InitialR2T': received No, accepted 0
9/19 7:33:26.266475 1db Params: iScsiParameter::update: <<< Boolean param 'ImmediateData': received Yes, accepted 1
9/19 7:33:26.266489 1db Params: iScsiParameter::update: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
9/19 7:33:26.266501 1db Params: iScsiParameter::update: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
9/19 7:33:26.266512 1db Params: iScsiParameter::update: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
9/19 7:33:26.266525 1db Params: iScsiParameter::update: <<< Numeric param 'MaxConnections': received 1, accepted 1
9/19 7:33:26.266537 1db Params: iScsiParameter::update: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
9/19 7:33:26.266548 1db Params: iScsiParameter::update: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
9/19 7:33:26.266561 1db Params: iScsiParameter::update: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
9/19 7:33:26.273537 1db T[1d,1]: iScsiTask::startLoginPhase: An old session [1c] from the same Initiator/ISID is there. Session reinstatement starting...
9/19 7:33:26.273570 1db S[1c]: iScsiSession::freeHanged: Exec queue is not empty (8 tasks)!
9/19 7:33:26.293942 1db Srv: *** SwSocket::Shutdown: shutdown() failed with error 10038!
9/19 7:33:26.293974 1db C[1c], LIN: iScsiConnection::terminate: Closing socket.
9/19 7:33:27.295697 1db T[1d,1]: iScsiTask::startLoginPhase: Old session [1c] to target 'iqn.2008-08.com.starwindsoftware:192.168.1.10-nas110' is still present. Login rejected!
9/19 7:33:27.295778 1db func: >>> iScsiServer::sendNotification
9/19 7:33:27.295790 1db func: >>> CEventDataBase::AddRecord
9/19 7:33:27.295800 1db EventDB: CEventDataBase::AddRecord: Code 275, severity 2, additional strings: 2
9/19 7:33:27.295838 1db func: <<< CEventDataBase::AddRecord
9/19 7:33:27.295848 1db Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 275).
9/19 7:33:27.295866 1db Srv: iScsiServer::sendNotification: Send reaction finish.
9/19 7:33:27.295876 1db Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 275).
9/19 7:33:27.296496 1db Srv: iScsiServer::sendNotification: Send reaction finish.
9/19 7:33:27.296524 1db Srv: iScsiServer::sendNotification: Send reaction start (reaction type 3, msg code 275).
9/19 7:33:27.296669 1db Srv: iScsiServer::sendNotification: Send reaction finish.
9/19 7:33:27.296688 1db func: <<< iScsiServer::sendNotification
9/19 7:33:27.296910 1d9 C[1d], IN_LOGIN: iScsiConnection::doTransition: Event - LOGIN_REJECT.
9/19 7:33:27.297272 1d9 Srv: *** SwSocket::Shutdown: shutdown() failed with error 10058!
9/19 7:33:27.549891 1db C[1d], IN_LOGIN: iScsiConnection::recvData: Recv - peer shutdown
9/19 7:33:27.549968 1db C[1d], IN_LOGIN: iScsiConnection::receive: recvData returned error 10058 (0x274a)!
9/19 7:33:27.550068 1db Srv: *** SwSocket::Shutdown: shutdown() failed with error 10058!
9/19 7:33:27.550176 1db Srv: *** SwSocket::Shutdown: shutdown() failed with error 10058!
9/19 7:33:27.550225 1db Srv: *** SwSocket::Shutdown: shutdown() failed with error 10058!
9/19 7:33:27.550305 1d4 S[1d]: iScsiSession::~iScsiSession: ~Session
9/19 7:33:29.828985 9 Srv: iScsiServer::listenConnections: Accepted iSCSI connection from a.b.c.1:44720 to a.b.c.10:3260. (Id = 0x1e)
9/19 7:33:29.829058 9 S[1e]: iScsiSession::iScsiSession: Session (00000000018208C0)
9/19 7:33:29.829073 9 C[1e], FREE: iScsiConnection::doTransition: Event - CONNECTED.
9/19 7:33:30.080522 1d8 C[1e], XPT_UP: iScsiConnection::handleFirstLogin: Login request: ISID 0x00023d000001, TSIH 0x0000.
9/19 7:33:30.080622 1d8 C[1e], XPT_UP: iScsiConnection::doTransition: Event - LOGIN.
9/19 7:33:30.080689 1d8 Params: iScsiParameter::update: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:xxxxxxxxxxxxxxxxxxxxxxxxxxxx:1242115180:64', accepted 'iqn.1998-01.com.vmwar
9/19 7:33:30.080713 1d8 Params: iScsiParameter::update: <<< String param 'InitiatorAlias': received 'iscsi_vmk', accepted 'iscsi_vmk'
9/19 7:33:30.080750 1d8 Params: iScsiParameter::update: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.1.10-nas110', accepted 'iqn.2008-08.com.starwindsoftware:192
168.1.10-nas110'
9/19 7:33:30.080766 1d8 Params: iScsiParameter::update: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
9/19 7:33:30.080779 1d8 Params: iScsiParameter::update: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
9/19 7:33:30.080793 1d8 Params: iScsiParameter::update: <<< Enum param 'DataDigest': received 'None', accepted 'None'
9/19 7:33:30.080809 1d8 Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
9/19 7:33:30.080821 1d8 Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
9/19 7:33:30.080833 1d8 Params: iScsiParameter::update: <<< Boolean param 'IFMarker': received No, accepted 0
9/19 7:33:30.080846 1d8 Params: iScsiParameter::update: <<< Boolean param 'OFMarker': received No, accepted 0
9/19 7:33:30.080860 1d8 Params: iScsiParameter::update: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
9/19 7:33:30.080871 1d8 Params: iScsiParameter::update: <<< Boolean param 'InitialR2T': received No, accepted 0
9/19 7:33:30.080885 1d8 Params: iScsiParameter::update: <<< Boolean param 'ImmediateData': received Yes, accepted 1
9/19 7:33:30.080899 1d8 Params: iScsiParameter::update: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
9/19 7:33:30.080910 1d8 Params: iScsiParameter::update: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
9/19 7:33:30.080920 1d8 Params: iScsiParameter::update: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
9/19 7:33:30.080932 1d8 Params: iScsiParameter::update: <<< Numeric param 'MaxConnections': received 1, accepted 1
9/19 7:33:30.080941 1d8 Params: iScsiParameter::update: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
9/19 7:33:30.080951 1d8 Params: iScsiParameter::update: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
9/19 7:33:30.080962 1d8 Params: iScsiParameter::update: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
9/19 7:33:30.086793 1d8 T[1e,1]: iScsiTask::startLoginPhase: An old session [1c] from the same Initiator/ISID is there. Session reinstatement starting...
9/19 7:33:30.086807 1d8 S[1c]: iScsiSession::freeHanged: Exec queue is not empty (8 tasks)!
9/19 7:33:30.107097 1d8 Srv: *** SwSocket::Shutdown: shutdown() failed with error 10038!
9/19 7:33:30.107123 1d8 C[1c], LIN: iScsiConnection::terminate: Closing socket.
9/19 7:33:31.109563 1d8 T[1e,1]: iScsiTask::startLoginPhase: Old session [1c] to target 'iqn.2008-08.com.starwindsoftware:192.168.1.10-nas110' is still present. Login rejected!
9/19 7:33:31.109645 1d8 func: >>> iScsiServer::sendNotification
9/19 7:33:31.109658 1d8 func: >>> CEventDataBase::AddRecord
9/19 7:33:31.109670 1d8 EventDB: CEventDataBase::AddRecord: Code 275, severity 2, additional strings: 2
How to avoid getting multiple copies of those warnings and what triggered them to start with, and can we avoid the problem at all?
Tue Sep 19, 2023 12:38 pm
Please check the underlying storage. It looks like there are some underlying storage issues there or there are underlying storage hiccups.
If VMDK is used for underlying storage, see this guide https://knowledgebase.starwindsoftware. ... ontroller/
