Open a VHDX (from Disk2vhd) leads to "Error opening file".
m.fessler
Sat Sep 02, 2023 7:18 pm
first of all, thank you very much for the V2V Converter - great software!
I noticed, when I try to open a VHDX created with Disk2vhd v2.02 as "Local file", I get the error message:
Error opening file (2) [0]
Error opening file
If I mount the VHDX in Windows first (in non read-only mode) and then unmount it, I can open it in V2V Converter.
When I create a VHD the problem does not occur.
Is anything known about this?
Maybe my workaround will help someone.
Thanks and greetings,
Martin
Sat Sep 02, 2023 7:46 pm
Thanks for your kind words!
This can be because it is picked up as a device from gen 1 VM and therefore does not see VHDX.
As a workaround, I'd suggest using VHD and then try this cmdlet https://learn.microsoft.com/en-us/power ... ver2022-ps
heromovie
Wed Nov 22, 2023 3:51 am
I tried using VHD as you said and it helped me solve my problem. Thank you.
Wed Nov 22, 2023 8:14 am
Thanks for sharing your experience!
