heberr
Fri Jul 28, 2023 6:37 pm
Hi There,
So I am trying to copy one Hyper-V VM to another Hyper-N Host and I keep getting the following error:
"Error creating image file" - Conversion Failed
I suspect maybe disk space? Not sure can you give me some guidance on how to troubleshoot the issue.
Thank you in advanced for any help you can provide.
- image of error
- Capture.JPG (39.38 KiB) Viewed 13025 times
heberr
Sat Jul 29, 2023 12:54 am
Plenty of disk space, disk health is fine and all checkpoint are merged. Any other suggestions?
Thank you for your response.
heberr
Sat Jul 29, 2023 1:29 am
Does the source VM need to be turned off, during this cloning process?
- Settings
- settings.JPG (64.84 KiB) Viewed 13010 times
- Error
- Capture.JPG (37.35 KiB) Viewed 13010 times
Sat Jul 29, 2023 1:49 am
Greetings,
Yes, please try shutting down the VM. Sadly the VM settings you shared do not contain the information I need. I need to see the disk the VM is using (Please press inspect disk).
heberr
Sat Jul 29, 2023 2:15 am
Here you go. Thanks
- Inspect Disk
- disk.JPG (34.12 KiB) Viewed 13005 times
