Error V2Ving from Aws to Hyper-V
Mlewis
Wed Jul 12, 2023 12:11 am
Followed the Starwind guide for Aws migration out and in to HyperV but getting the following errors:
Error creating bucket.
Error opening image.
Unable to parse exception name InvalidAdBucketWidthObjectOwnership...
With the last error like being the clue.
Any ideas?
Wed Jul 12, 2023 7:33 am
Please review the privileges AWS account has. The issue is related to insufficient privileges.
Mlewis
Wed Jul 12, 2023 3:48 pm
That's what I thought as well but I followed the article in the help file:
https://www.starwindsoftware.com/v2v-he ... vices.html
But I am still getting this error.
What should I check specifically? I created the Access Keys from the AWS root user, opened the ports in the security group that's associated with the instance, and I created a key pair. Not sure what else to do.
Thu Jul 13, 2023 7:49 am
The issue is on the AWS side as the application cannot make the changes using the credentials you supplied.
Try the following:
1. Make sure you are logged as root.
2. Create a bucket and the access key for it.
3. Try conversion over again.
Mlewis
Thu Jul 13, 2023 2:56 pm
yaroslav (staff) wrote:The issue is on the AWS side as the application cannot make the changes using the credentials you supplied.
Try the following:
Hi. I'm logged in as root. I've created a new bucket with ACLs disabled and public access disabled. I've created a new access key. Same problem.
I've also tried this on a totally different AWS organization using that orgs root account with same results.
There has to be some prerequisite that's not mentioned in the Starwind documentation that's not being met. Would you please double check with your team on this?
Thank you for the assistance. Greatly appreciated.
Fri Jul 14, 2023 11:31 am
This can be the key.
I ran the conversion with my personal AWS account without a hitch.
Can you please try creating a new AWS account to double-check that?
Mlewis
Fri Jul 14, 2023 2:32 pm
yaroslav (staff) wrote:Hi,
Are you saying to make sure that ACL's are disabled and public access is also disabled in this new account?
Fri Jul 14, 2023 3:39 pm
Sorry for misleading you. I read a bit more about this issue. Any new account should have ACLs (https://docs.aws.amazon.com/AmazonS3/la ... rview.html) and public access (https://docs.aws.amazon.com/AmazonS3/la ... ucket.html) disabled by default.
The error you faced seems to be a result of recent changes in AWS.
What I found (recent thread) is https://stackoverflow.com/questions/760 ... enforced-s.
More detail https://docs.aws.amazon.com/AmazonS3/la ... rship.html and https://stackoverflow.com/questions/760 ... ror-for-my.
What I am trying to say is that something got changed on the AWS side recently. I will log a call with R&D to see if it can be worked around on our side.
Mlewis
Fri Jul 14, 2023 4:04 pm
yaroslav (staff) wrote:Sorry for misleading you. I read a bit more about this issue. Any new account should have ACLs (https://docs.aws.amazon.com/AmazonS3/la ... rview.html) and public access (https://docs.aws.amazon.com/AmazonS3/la ... ucket.html) disabled by default.
If it's working in your account, would you mind sharing all of the settings with me?
Mlewis
Mon Jul 17, 2023 4:54 pm
Just bumping this, really need to get this working.
Tue Jul 18, 2023 9:07 am
Please log a call with us at support@starwind.com.
Use link to this thread and 972402 as your references.
Just wanted to mention that the issue is on the AWS side, we will need time to implement and test the workaround on our side.
Mlewis
Tue Jul 18, 2023 10:40 pm
yaroslav (staff) wrote:Please log a call with us at support@starwind.com.
OK support case has been logged.
I'm available at your convenience to troubleshoot this.
Tue Jul 18, 2023 10:49 pm
R&D is working on the workaround. I will keep you posted in the support case.
avdwalt86
Fri Jul 05, 2024 3:49 am
Has there been any workaround identified for this issue?
Tue Jul 09, 2024 8:46 am
The fix is available in the latest build.
