P2V Windows XP to VMWare
xipopep179
Thu Jun 15, 2023 3:00 pm
Hi everyone,
I would like to P2V an old 32 bits Windows XP computer to a VM. I tried all in-built Windows solutions (NT, backup, ...) but to no avail. Someone recomanded me Starwind P2V but unfortunately I cannot run it on Windows XP.
It says "Internal error : Cannot expand "pf64" constant on this version of Windows".
Does anyone know if there is another version of Starwind P2V that is compatible or soma trick to make it work ?
Thank you,
Xipopep
Thu Jun 15, 2023 4:44 pm
Sadly, P2V conversion of 32bit OS is not available.
xipopep179
Fri Jun 16, 2023 2:04 pm
If I connect my Windows XP (32 bits) computer internal drive as an external drive of my Windows 10 computer, can I make a P2V if the W32 computer ?
Mon Jun 19, 2023 9:32 am
If it is recognized by the converter, yes, but StarWind V2V Converter might not support the conversion of the external disks.
