CreateImage Plugin is not supported
erion2022
Sun Apr 16, 2023 8:07 pm
Hi all.
I've been strungling with this powershell script to create imagefile without success.
I've created VLT device without problem.
I don't know where to check anymore:
Here is my script:
param($addr="127.0.0.1", $port=3261, $user="root", $password="starwind",
$fileName="img1.img",
$starwindfiletype="img",
$filePath="My Computer\C\starwind",
$size=12,
$targetAlias="targetimg1",
$sectorSize=512,
$numaNode=0,
$cacheMode="wb",
$cacheSize=128)
Import-Module StarWindX
try
Enable-SWXLog
if($sectorSize -eq 4096 -and $size -lt 2)
throw "Minimal device size 2MB"
$server.Connect()
Write-Host "Creating ImageFile" (just to understand where the script fail)
#create image file
New-ImageFile -server $server -path "My Computer\C\starwind" -fileName "img1.img" -size 2048
Write-Host "Creating ImageDevice" (just to understand where the script fail)
#create device
$device = Add-ImageDevice -server $server -path "My Computer\C\starwind" -fileName "img1.img" -sectorSize $sectorSize -NumaNode $numaNode -CacheMode $cacheMode -CacheSize $cacheSize
$device
Write-Host "Creating Target" (just to understand where the script fail)
#create target
$target = New-Target -server $server -alias $targetAlias -devices $device.Name
$target
catch
Write-Host $_ -foreground red
finally
$server.Disconnect()
Plugin is not supported.png (4.37 KiB) Viewed 7754 times
Sun Apr 16, 2023 9:09 pm
Are you running StarWind Service on the host where you running the script? Are you planning a standalone device?
Try $fileName="img1", also make sure the folder exists.
Please also note that write-back caching can result in data loss for non-replicated devices in case of service termination or power outage. In other words, please make sure to create a device with no cache.
erion2022
Sun Apr 16, 2023 10:02 pm
Well, this is just a lab for testing purposes.
What I realize is that I was using a free VLT license. I have installed a free vsan license and I was able to create image and vlt device.
Thank you.
Mon Apr 17, 2023 8:30 am
StarWind VTL is a whole different device type as compared to the *img.
Were you able to create the *.img with the script suggestion mentioned above?
