V2V between datacentres fails.
coolts
Wed Mar 08, 2023 2:40 pm
Hi
My old datacentre runs ESXI 6.5.0 and my new one 7.0.3. I need to move VM's between them.
I point the app at both and initiate the move which fails. Here is the log.
The log file name: 'logs\V2V_Log-20230308-142043.log' (PID 23784)
3/8 14:20:43.871 1744 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
3/8 14:20:43.871 1744 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
3/8 14:20:43.874 1744 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
3/8 14:20:43.874 1744 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
3/8 14:20:43.877 1744 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 22621
3/8 14:20:43.879 1744 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - cbfd0000
3/8 14:20:43.880 1744 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - cbfd0000
3/8 14:20:48.115 1744 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
3/8 14:22:03.271 1744 Facility ???INFO: WrapperESXI::connect: m_url - https://10.4.224.85/sdk
3/8 14:22:06.070 1744 Facility ???INFO: WrapperESXI::connect: fullName - , key - 5214f70a-9b04-a01c-dc43-f2dc91322b21
3/8 14:22:06.070 1744 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
3/8 14:22:06.829 1744 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.5.0
3/8 14:22:50.484 1744 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
3/8 14:22:52.219 1744 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
3/8 14:23:15.944 1744 Facility ???INFO: WrapperESXI::connect: m_url - https://10.0.10.15/sdk
3/8 14:23:15.972 1744 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 52afe5cf-5543-3035-b16c-734e493e7075
3/8 14:23:15.972 1744 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
3/8 14:23:16.034 1744 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
3/8 14:23:47.105 1744 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
3/8 14:23:47.121 2c50 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 6
3/8 14:23:47.888 2c50 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-3026
3/8 14:23:47.888 2c50 Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-3026
3/8 14:23:47.979 2c50 Facility ???INFO: CPPConverting::ConvertImage: pathInput: [Workstation] LabTest01/LabTest01.vmdk, pathOutput: [VxRail-Virtual-SAN-Datastore-3e657206-e8bf-445a-85eb-1dbb496a49fc] LabTest01/LabTest01.vmdk
3/8 14:23:48.079 2c50 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Workstation] LabTest01/LabTest01.vmdk
3/8 14:23:48.079 2c50 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-14455
3/8 14:23:48.082 2c50 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 7E:ED:14:B0:E8:F1:C5:2B:4C:56:01:BE:FF:70:31:1D:7B:F4:A1:0E
3/8 14:23:52.281 2c50 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
3/8 14:23:53.604 2c50 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [VxRail-Virtual-SAN-Datastore-3e657206-e8bf-445a-85eb-1dbb496a49fc] LabTest01/LabTest01.vmdk
3/8 14:23:53.604 2c50 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-3026
3/8 14:23:53.604 2c50 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 0A:32:C8:03:95:CE:70:50:58:AA:56:53:57:B0:DD:4F:88:AA:05:20
3/8 14:23:53.713 2c50 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 4, A file was not found
3/8 14:23:53.713 2c50 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
3/8 14:23:53.713 2c50 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
3/8 14:23:53.745 2c50 Facility ???INFO: WrapperESXI::connect: m_url - https://10.4.224.85/sdk
3/8 14:23:54.006 2c50 Facility ???INFO: WrapperESXI::connect: fullName - , key - 52b77618-dcbe-b259-4fb9-60244d58b7f0
3/8 14:23:54.006 2c50 Facility ???ERROR: CPPConverting::Convert: FAILED
I have admin rights to both datacentres.
Wed Mar 08, 2023 5:58 pm
Is any of them running a free version?
Also, as a workaround, you can back up the VMs from the old location and restore them in the new location. Finally, you can move the VM between clusters with Enhanced vMotion: just add an old server to the new cluster and move the VMs from the old server to any of the new ones.
coolts
Thu Mar 09, 2023 8:39 am
HI Yaroslav
No, both fully licensed. I am going to try using my backup software (VEEAM), as it can see both clusters. The issue is that the server restore would be from a previous nights backup. Not too bad if i do it early doors, (7am,etc as the backup will only be a few hours old).
My old cluster is in production and if i add one of its hosts to the new cluster, i was worried it might break something or interrupt the vm's.
Thu Mar 09, 2023 10:10 am
V2V conversion also needs the VM to be down for the entire conversion time.
By the way, was the VM turned off during conversion?
coolts
Fri Mar 10, 2023 7:58 am
mystery file.png (170.76 KiB) Viewed 7919 times
Yes, it was down.
This is where it goes wrong;
On the destination datacentre, a VM is created but with no bootable drive.
files are there but the destination .vmdk is double the size and there's a mystery .vswp file the size of the original .vmdk
Fri Mar 10, 2023 9:02 am
Thanks for your details.
Can you perform Storage vMotion between these servers?
Can you try converting an individual drive?
