V2V - Azure to Esxi Error sending request to Azure
lrusso
Sat Feb 25, 2023 9:09 pm
I have been trying for several days to migrate one of my Azure linux virtual machines to my ESXi infrastructure.
The Azure VM has 2 disks, the first one of 60 GB (OS_Disk) works very well, however when StarWind migrates the second disk which is 1 TB, after several hours I get the error "Error sending request to Azure The access token UTC time 'X/XX/XXX' is earlier than the current UTC time 'X/XX/XXX'"... (attached file)
Capture d’écran 2023-02-25 à 21.59.57.png (36.05 KiB) Viewed 3956 times
I also give you the log file :
https://pastebin.com/jSpMsYKt
thank you in advance for your help.
Sun Feb 26, 2023 1:33 pm
This looks to be a connection problem to Azure, not an issue with the V2V converter. Access token expires earlier than the file is uploaded. See more on how to expand expiration time at https://learn.microsoft.com/en-us/answe ... zure-porta.
