error converting physical disk to ESXI growable image
gnesper
Thu Jan 12, 2023 5:12 pm
Hello everybody.
I'm trying to convert the physical disk of a running machine, the same one where I installed starwind converter.
The procedure I follow is the following:
P2V -> Physical Disk (I choose both the C drive and the boot partition) -> local file ->VMDK->ESXi Server image->ESXi growable image.
At this point I can choose to also save the file to a network location with enough space to hold the file.
Once the conversion has started, these errors pop up:
error creating image
Invalid parameter
Conversion failed
I tried this procedure both with a physical (non-virtual) windows 10 client pc and with a physical (non-virtual) windows 2012 server, but the result is always the same
thank you
Thu Jan 12, 2023 11:50 pm
Could you please tell me more about the source OS and ESXi version you are using?
ESXi Free might not support certain APIs V2V Converter uses.
gnesper
Fri Jan 13, 2023 4:55 pm
the source OS is Windows Server 2012 Foundation 64 bit and it's not virtual, but it's physical.
I just tried to create a backup from physical server to to vmdk file
If I do the same steps but select "ESXi pre-allocadet image" the convertion proccess is successful.
So, the error pops up only if I choose "ESXi growable image"
thank you
Fri Jan 13, 2023 10:40 pm
Can I have the full set of logs, please? You can find them under V2V Convertor's directory in the logs folder.
gnesper
Thu Jan 19, 2023 5:12 pm
Hi. I can't attach the log file (error about the format).
Here is the content:
The log file name: 'logs\V2V_Log-20230119-175433.log' (PID 2728)
1/19 17:54:33.451 db8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
1/19 17:54:33.451 db8 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
1/19 17:54:33.472 db8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
1/19 17:54:33.472 db8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
1/19 17:54:33.476 db8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 2, BuildNumber 9200
1/19 17:54:33.505 db8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 4cf50000
1/19 17:54:33.506 db8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 4cf50000
1/19 17:54:45.648 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
1/19 17:54:52.817 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelect
1/19 17:54:55.288 db8 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eTypeP2V
1/19 17:54:57.113 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
1/19 17:54:59.953 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
1/19 17:55:07.153 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
1/19 17:55:27.552 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsVMware
1/19 17:55:33.665 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsESXI
1/19 17:55:40.912 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
1/19 17:56:04.281 db8 Facility ???INFO: CPPOutputFile::onNext: Out path: \\192.168.0.105\server_sici\copia virtuale\SERVEjjjjjjj.vmdk, Out format 13
1/19 17:56:04.281 db8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
1/19 17:56:04.364 16a4 Facility ???INFO: CPPConverting::Convert: InConvertType: 2, OutConvertType: 4
1/19 17:56:04.364 16a4 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 0, pathOutput: \\192.168.0.105\server_sici\copia virtuale\SERVEjjjjjjj.vmdk
1/19 17:56:04.462 16a4 Facility ???INFO: P2V::CreateInputImage: path 0
1/19 17:56:04.579 16a4 Facility ???INFO: P2V::CreateInputImage: Size 0 - 498999492608, BytesPerSector - 512
1/19 18:00:22.896 16a4 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
1/19 18:00:28.174 16a4 Facility ???INFO: VMwareFile::NewFile: sFileName - \\192.168.0.105\server_sici\copia virtuale\SERVEjjjjjjj.vmdk
1/19 18:00:28.215 16a4 Facility ???INFO: VMwareFile::NewFile: SectorType - 974608384
1/19 18:00:28.215 16a4 Facility ???INFO: VMwareFile::NewFile: EVMDKCreateType - 1
1/19 18:00:28.215 16a4 Facility ???INFO: VMwareFile::NewFile: EVMDKAdapterType - 0
1/19 18:00:28.215 16a4 Facility ???INFO: VMwareFile::NewFile: createType is fail - 1
1/19 18:00:28.215 16a4 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 19
1/19 18:00:28.247 16a4 Facility ???ERROR: CPPConverting::Convert: FAILED
Fri Jan 20, 2023 8:53 am
Does the location have enough space to accommodate the thick disk?
gnesper
Fri Jan 20, 2023 10:07 am
yes, if choose ESXi pre-allocadet image the backup works fine
Sun Jan 22, 2023 12:22 am
Thank you for your update.
Is 192.168.0.105 the IP address of vCenter or the ESXi host?
gnesper
Fri Jan 27, 2023 4:49 pm
192.168.0.105 is the address of the NAs where I want to save the file
Sat Jan 28, 2023 7:05 pm
Can you browse that location in the V2V converter GUI?
Please try converting it to ESXi host.
ts2340
Mon Aug 21, 2023 7:54 pm
So I'm having this same issue.. I can convert to a local ESXI image if I choose pre-allocated but it errors out when I choose growable image (saving in the same location)..
Any ideas? Thanks
Mon Aug 21, 2023 10:38 pm
Can you please share the conversion logs?
ts2340
Tue Aug 22, 2023 7:08 pm
yaroslav (staff) wrote:Hi,
Thanks for the reply. Here you go:
The log file name: 'logs\V2V_Log-20230822-200247.log' (PID 32936)
8/22 20:02:47.700 3640 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
8/22 20:02:47.700 3640 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
8/22 20:02:47.700 3640 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
8/22 20:02:47.700 3640 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
8/22 20:02:47.700 3640 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 14393
8/22 20:02:47.715 3640 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ea150000
8/22 20:02:56.603 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnection
8/22 20:02:57.510 3640 Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
8/22 20:02:57.577 3640 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.14393
8/22 20:02:57.577 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/22 20:03:04.056 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/22 20:03:06.815 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
8/22 20:03:09.320 3640 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocationTo
8/22 20:03:15.835 3640 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eInputVM
8/22 20:03:22.060 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/22 20:03:24.137 3640 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eInputVM
8/22 20:03:27.469 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/22 20:03:35.970 3640 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eInputVM
8/22 20:03:36.566 3640 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eHYPERVConnection
8/22 20:03:37.580 3640 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
8/22 20:03:40.989 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputFile
8/22 20:04:01.435 3640 Facility ???INFO: CPPInputFile::checkFile: Select file: E:\Virtual Machines\SERVER\SERVER_HardDisk0.vhdx
8/22 20:04:01.435 3640 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
8/22 20:04:01.435 3640 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
8/22 20:04:01.435 3640 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
8/22 20:04:01.435 3640 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
8/22 20:04:01.450 3640 Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
8/22 20:04:01.466 3640 Facility ???INFO: CPPInputFile::checkFile: ParseFile: 0
8/22 20:04:01.466 3640 Facility ???INFO: CPPInputFile::checkFile: File type: IDS_IMAGE_CONVERTER_FORMAT_NAME_VHDX_SPARSE  File size: 266338304 sectors
8/22 20:04:03.265 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/22 20:04:06.427 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
8/22 20:04:11.483 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsVMware
8/22 20:04:14.284 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsESXI
8/22 20:04:16.877 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
8/22 20:04:38.082 3640 Facility ???INFO: CPPOutputFile::onNext: Out path: C:\ManagedClient\SERVER.vmdk, Out format 13
8/22 20:04:38.094 3640 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
8/22 20:04:38.107 8394 Facility ???INFO: CPPConverting::Convert: InConvertType: 4, OutConvertType: 4
8/22 20:04:38.108 8394 Facility ???INFO: CPPConverting::ConvertImage: pathInput: E:\Virtual Machines\SERVER\SERVER_HardDisk0.vhdx, pathOutput: C:\ManagedClient\SERVER.vmdk
8/22 20:04:38.108 8394 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
8/22 20:04:38.108 8394 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
8/22 20:04:38.108 8394 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
8/22 20:04:38.109 8394 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
8/22 20:04:38.109 8394 Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
8/22 20:04:38.109 8394 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
8/22 20:04:38.273 8394 Facility ???INFO: VMwareFile::NewFile: sFileName - C:\ManagedClient\SERVER.vmdk
8/22 20:04:38.273 8394 Facility ???INFO: VMwareFile::NewFile: SectorType - 266338304
8/22 20:04:38.273 8394 Facility ???INFO: VMwareFile::NewFile: EVMDKCreateType - 1
8/22 20:04:38.273 8394 Facility ???INFO: VMwareFile::NewFile: EVMDKAdapterType - 0
8/22 20:04:38.273 8394 Facility ???INFO: VMwareFile::NewFile: createType is fail - 1
8/22 20:04:38.273 8394 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 19
8/22 20:04:38.273 8394 Facility ???ERROR: CPPConverting::Convert: FAILED
ts2340
Tue Aug 22, 2023 7:23 pm
And here's a working one on the same server but chosing pre-allocated..
The log file name: 'logs\V2V_Log-20230822-201606.log' (PID 27600)
8/22 20:16:06.032 3a18 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
8/22 20:16:06.032 3a18 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
8/22 20:16:06.036 3a18 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
8/22 20:16:06.036 3a18 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
8/22 20:16:06.041 3a18 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 14393
8/22 20:16:06.046 3a18 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ea150000
8/22 20:16:06.047 3a18 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ea150000
8/22 20:16:12.251 3a18 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputFile
8/22 20:16:45.638 3a18 Facility ???INFO: CPPInputFile::checkFile: Select file: E:\Virtual Machines\SERVER\SERVER_HardDisk0.vhdx
8/22 20:16:45.645 3a18 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
8/22 20:16:45.646 3a18 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
8/22 20:16:45.646 3a18 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
8/22 20:16:45.646 3a18 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
8/22 20:16:45.648 3a18 Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
8/22 20:16:45.652 3a18 Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
8/22 20:16:45.657 3a18 Facility ???INFO: CPPInputFile::checkFile: ParseFile: 0
8/22 20:16:45.658 3a18 Facility ???INFO: CPPInputFile::checkFile: File type: IDS_IMAGE_CONVERTER_FORMAT_NAME_VHDX_SPARSE  File size: 266338304 sectors
8/22 20:16:47.361 3a18 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/22 20:16:49.717 3a18 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
8/22 20:16:51.466 3a18 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsVMware
8/22 20:16:53.833 3a18 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsESXI
8/22 20:16:56.617 3a18 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
8/22 20:17:16.307 3a18 Facility ???INFO: CPPOutputFile::onNext: Out path: C:\ManagedClient\SERVER_HardDisk.vmdk, Out format 14
8/22 20:17:16.307 3a18 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
8/22 20:17:16.319 15c Facility ???INFO: CPPConverting::Convert: InConvertType: 4, OutConvertType: 4
8/22 20:17:16.320 15c Facility ???INFO: CPPConverting::ConvertImage: pathInput: E:\Virtual Machines\SERVER\SERVER_HardDisk0.vhdx, pathOutput: C:\ManagedClient\SERVER_HardDisk.vmdk
8/22 20:17:16.321 15c Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
8/22 20:17:16.321 15c Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
8/22 20:17:16.321 15c Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
8/22 20:17:16.321 15c Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
8/22 20:17:16.321 15c Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
8/22 20:17:16.322 15c Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
8/22 20:17:16.322 15c Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
8/22 20:17:16.471 15c Facility ???INFO: VMwareFile::NewFile: sFileName - C:\ManagedClient\SERVER_HardDisk.vmdk
8/22 20:17:16.471 15c Facility ???INFO: VMwareFile::NewFile: SectorType - 266338304
8/22 20:17:16.471 15c Facility ???INFO: VMwareFile::NewFile: EVMDKCreateType - 3
8/22 20:17:16.471 15c Facility ???INFO: VMwareFile::NewFile: EVMDKAdapterType - 0
8/22 20:17:16.559 15c Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
8/22 20:20:39.670 15c Facility ???INFO: CPPConverting::ConvertImage: Success
8/22 20:20:39.770 15c Facility ???INFO: CPPConverting::Convert: SUCCESSFULLY
Fri Aug 25, 2023 9:24 am
Hi, just to confirm: are you converting a VHDX to a local device or ESXi datastore?
UPDATE: You were converting to the VM ESXi file (i.e., something that is the part of the VM). It is not expected to be available as a local file.
