trouble with windows 7 image and VMWare
etsoft
Sat Nov 26, 2022 1:19 pm
after using your conversion of a windows 7 drive, I have trouble getting it to run in VmWare Workstation. It keeps going into recovery mode.
Do you have some hints on solving this?
Regards
Erwin
Sat Nov 26, 2022 8:49 pm
Do you have nay special (i.e., custom) drivers installed?
graceperez
Mon May 15, 2023 10:35 am
If you still have this issue, you can navigate to the installation directory for VMware Workstation Pro. This should be located by default in C:Program Files (x86)VMwareVMware Workstation. Then, find the executable file vmware.exe and give it a new name, such as vmwarea.exe. To make the modifications effective, restart the device. Hope that it's effective with you.
Mon May 15, 2023 11:10 am
I do not think that helps to be honest as the issue appears to be related to custom drivers of some sort.
