V2V Converter - Error 32768
Guest27
Mon Sep 19, 2022 6:46 am
Context :
2 ESXi 6.5 servers
2 Hyper-V 2022 Standard Edition
So far, I have fully migrated 8 VMs out of 12, from ESXi to Hyper-V, without any trouble, thanks to StarWind V2V Converter
But I encountered an error as for the 9th VM : Cannot attach Virtual Hard Disk
VM is Windows Server 2016, 2 disks (system and datas). System is converted OK, but it cannot convert Datas.
I cannot mount .VHD disk as well.
I've made a few trials, same error.
There was a corruption on the original disk that i've fixed with chkdsk, but the problem is still present
You can find the log as attachment
Best Regards,
V2V_Log-20220918-094326.zip
(2.69 KiB) Downloaded 369 times
Wed Sep 21, 2022 8:50 am
Is it a problem when connecting the disk to the VM?
The conversion runs fine, but there, I believe is a problem with the header for that specific disk. Do data migration to another (i.e., new) VMDK and try converting it.
