Synchronous replication
sahara
Thu Sep 15, 2022 11:54 am
I am searching for a solution on an synchronous active-active replication method in vcenter. VMs are on site 1 and need to be sent to site 2 for a quick RTO if site 1 goes down. Then, when site 1 is back it needs to sync the changes made on site 2 back to site 1. Of course, other backup servcies are in place but a restore and such takes much longer.
The sites are connected ONLY via mpls, so the storage systems do not see each other. So it should work over IP. Both sites have Vcenter and ESXi.
Is this something I can achieve with StarWind?
Thanks!!
Fri Sep 16, 2022 3:17 pm
Yes, please check this out https://www.starwindsoftware.com/starwind-virtual-san.
Please contact us at support@starwind.com if you have more questions.
