P2V to vCenter fails
hsantamaria9766
Wed Aug 10, 2022 1:44 pm
Trying to convert Windows 10 workstation to a VM on ESX 7.0.3 I can connect to vCenter with no issue. Choose the host and storage and vnet. When it goes to create the VM it fails. I see the vm created in vCenter and the vmdx but it is set to 1KB. It actually fails to fully create the disk. In the logs it says failed to communicate with host. Ports 80 and 443 are open to vCenter. Access to the host itself is only allowed from vCenter.
Part of log files is as below:
8/9 9:24:38.998 4cc8 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [oves256-2-c2-vm-paws-vol-1] hsantamaria-PC-VM/HDD0.vmdk
8/9 9:24:38.998 4cc8 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-179055
8/9 9:24:39.006 4cc8 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 1B:A0:A7:FE:BE:33:86:C4:27:04:CE:28:5D:BA:60:BB:EB:D6:36:B7
8/9 9:25:00.293 4cc8 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 18000, Cannot connect to the host
8/9 9:25:00.293 4cc8 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
8/9 9:25:00.293 4cc8 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
8/9 9:25:00.293 4cc8 Facility ???ERROR: CPPConverting::Convert: FAILED
Any ideas?
Thu Aug 11, 2022 8:20 am
Greetings,
Welcome to StarWind Forum. As a workaround, could you try converging the disk to a VMDK on that server? Please also try connecting to ESXi, not vCentre.
