audi911
Sat Jun 18, 2022 4:49 am
I'm trying to convert my VMWare Server 2016 server to HV and it keeps failing. I'm at a bit of a loss I don't really understand why I've done this many times.
From the HV machine I run the converter and vCenter starts it's snapshot. The snapshot goes to 66% and then jumps to 100% and errors with a failed to quiesce the virtual machine.
I'm thinking to myself (it's never happened before) that the virtual machine but I cannot shut off the VM. So I'm thinking that I am going to copy the contents of the virtual machine and try to convert them to vhdx when they are offline but no matter what I do whether it's from winscp / datastore browser from vCenter or from the host I cannot copy the vmdk.flat file. Every file copies correctly except for the flats and the flats are the actual hard disk files as far as I can tell they are huge.
Can anyone help me out I don't really know what to do, how can I convert a live VM to HV without it erroring out?
audi911
Tue Jun 21, 2022 7:32 pm
Hello!
Thanks for the reply.
The current server is running under a VMWare environment and we are moving towards a Hyper-V environment. We want to simply convert the ESX machine to a Hyper-V machine so we can make the upgrades accordingly when we are ready.
Unfortunately, every time we try to convert it it fails.
The log posts the following as errors
12/12 2:13:24.202 9c0 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
12/12 2:13:24.202 9c0 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
I am unsure this is an issue of the VM being open because I have already converted VMs in their running state I'm unsure what the issue is here.
Any help would be greatly appreciated.
Wed Jun 22, 2022 1:42 pm
Try shutting down the VM and converting the disk.
You can also copy the VM disk to the Hyper-V server (i.e., destination) and convert it as a local file.
audi911
Wed Jun 22, 2022 4:25 pm
I'm trying to do exactly that. I cannot copy the file it fails no matter what I do. The VMDK-flat file (the gigantic file) always fails. No matter what I do no matter what tool I use fails
Every other file works except for the flat files
audi911
Fri Jun 24, 2022 1:20 pm
Sure I can report the error shortly. But starwind software fails during conversion because it takes a snapshot and then for whatever reason the error is "failed to quiesce the virtual machine"
Fri Jun 24, 2022 3:09 pm
Greetings,
Could you do conversion of the VHDX locally? If the file copying itself fails. the same thing might be not letting conversion happen.
