Error when converting .img to esxi file
enty
Thu Jun 09, 2022 7:16 pm
I'm trying to convert an IMG file to ESXI
an error happend
the image can be downloaded here:
https://github.com/coolsnowwolf/lede/re ... ed-efi.rar
enty
Thu Jun 09, 2022 7:22 pm
2022-06-10T03:08:18.276+|| I125: Log for VMware Virtual Disk Development Kit pid=18684 version=6.5.4 build=build-13861102 option=Release
2022-06-10T03:08:18.276+|| I125: The process is 64-bit.
2022-06-10T03:08:18.276+|| I125: Host codepage=windows-936 encoding=GBK
2022-06-10T03:08:18.276+|| I125: Host is Windows 8 Pro, 64-bit (Build 9200)
2022-06-10T03:08:18.275+|| I125: FILE: FileDeletionRetry: Non-retriable error encountered (C:\Users\enty\AppData\Local\Temp\vmware-enty\vixDiskLib-18684-2.log): The system cannot find the file specified (2)
2022-06-10T03:08:18.276+|| I125: OBJLIB-LIB: Objlib initialized.
2022-06-10T03:08:18.276+|| I125: VixDiskLib: Attempting to locate advanced transport module in "lib".
2022-06-10T03:08:18.277+|| I125: VixDiskLib: Could not load default plugins from lib\bin\disklibplugin.dll: Cannot open library: The specified module could not be found.
2022-06-10T03:08:18.277+|| I125: VixDiskLib: Advanced transport module not loaded.
2022-06-10T03:08:18.277+|| I125: VixDiskLib: Using transport modes from DiskLib: file:nbdssl:nbd.
2022-06-10T03:08:18.277+|| I125: VMware VixDiskLib (6.5) Release build-13861102
2022-06-10T03:08:18.277+|| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:\ProgramData\VMware): Cannot create a file when that file already exists (183)
2022-06-10T03:08:18.277+|| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:\ProgramData\VMware\VMware Virtual Disk Development Kit): Cannot create a file when that file already exists (183)
2022-06-10T03:08:18.277+|| I125: DictionaryLoad: Cannot open file "C:\ProgramData\VMware\VMware Virtual Disk Development Kit\config.ini": The system cannot find the file specified.
2022-06-10T03:08:18.277+|| I125: [msg.dictionary.load.openFailed] Cannot open file "C:\ProgramData\VMware\VMware Virtual Disk Development Kit\config.ini": The system cannot find the file specified.
2022-06-10T03:08:18.277+|| I125: PREF Optional preferences file not found at C:\ProgramData\VMware\VMware Virtual Disk Development Kit\config.ini. Using default values.
2022-06-10T03:08:18.277+|| I125: DictionaryLoad: Cannot open file "C:\ProgramData\VMware\VMware Virtual Disk Development Kit\settings.ini": The system cannot find the file specified.
2022-06-10T03:08:18.277+|| I125: [msg.dictionary.load.openFailed] Cannot open file "C:\ProgramData\VMware\VMware Virtual Disk Development Kit\settings.ini": The system cannot find the file specified.
2022-06-10T03:08:18.277+|| I125: PREF Optional preferences file not found at C:\ProgramData\VMware\VMware Virtual Disk Development Kit\settings.ini. Using default values.
2022-06-10T03:08:18.277+|| I125: DictionaryLoad: Cannot open file "C:\Users\enty\AppData\Roaming\VMware\config.ini": The system cannot find the file specified.
2022-06-10T03:08:18.277+|| I125: [msg.dictionary.load.openFailed] Cannot open file "C:\Users\enty\AppData\Roaming\VMware\config.ini": The system cannot find the file specified.
2022-06-10T03:08:18.277+|| I125: PREF Optional preferences file not found at C:\Users\enty\AppData\Roaming\VMware\config.ini. Using default values.
2022-06-10T03:08:18.277+|| I125: UUID: SMBIOS UUID is reported as 'ca df 82 fa 2e 0f 17 09-28 16 24 4b fe 8f 2c cf'.
2022-06-10T03:08:18.277+|| I125: FILE: FileLockDynaLink: Further process validation tools are: available
2022-06-10T03:08:18.283+|| I125: lib/ssl: OpenSSL using FIPS_drbg for RAND
2022-06-10T03:08:18.284+|| I125: lib/ssl: protocol list tls1.2
2022-06-10T03:08:18.284+|| I125: lib/ssl: protocol list tls1.2 (openssl flags 0x17000000)
2022-06-10T03:08:18.284+|| I125: lib/ssl: cipher list !aNULL:kECDH+AESGCM:ECDH+AESGCM:RSA+AESGCM:kECDH+AES:ECDH+AES:RSA+AES
2022-06-10T03:08:18.284+|| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:\ProgramData\VMware): Cannot create a file when that file already exists (183)
2022-06-10T03:08:18.288+|| I125: 2022-06-10T03:08:18.288+08:00 PREF early PreferenceGet(poll.forceSelect), using default
2022-06-10T03:08:18.288+|| I125: 2022-06-10T03:08:18.288+08:00 POLL Using the WSAPoll API Implementation for PollDefault
2022-06-10T03:08:18.306+|| I125: 2022-06-10T03:08:18.306+08:00 VixDiskLibVim: VixDiskLibVim_Init: Initialization is completed.
2022-06-10T03:08:18.306+|| I125: VixDiskLib: VixDiskLib_Connect: Establish connection.
2022-06-10T03:08:18.306+|| I125: VixDiskLib: VixDiskLib_Create: Create a disk.
2022-06-10T03:08:18.306+|| I125: DISKLIB-LIB_CREATE : CREATE: "E:\o?鴖\openwrt\openwrt-x64-R22.5.5-generic-squashfs-combined-efi.vmdk" -- vmfs capacity=361024 (176.3 MB) adapter=ide info=cowGran=0 allocType=1 objType= policy=''
2022-06-10T03:08:18.306+|| I125: DISKLIB-LIB_CREATE : CreateObjExtParams: Object backing type 0 is invalid. Figuring out the most suitable backing type...
2022-06-10T03:08:18.306+|| I125: PANIC: NOT_IMPLEMENTED d:/build/ob/bora-13861102/bora/lib/unicode/unicodeSimpleBase.c:741
2022-06-10T03:08:18.306+|| I125: Backtrace:
2022-06-10T03:08:18.309+|| W115: Win32 object usage: GDI 120, USER 120
2022-06-10T03:08:18.309+|| I125: CoreDump_CoreDump: faking exception to get context
2022-06-10T03:08:18.309+|| I125: CoreDump: Minidump file C:\Users\enty\AppData\Local\Temp\vmware-enty\v2v_converter.dmp exists. Rotating ...
2022-06-10T03:08:18.309+|| I125: FILE: FileDeletionRetry: Non-retriable error encountered (C:\Users\enty\AppData\Local\Temp\vmware-enty\v2v_converter-3.dmp): The system cannot find the file specified (2)
2022-06-10T03:08:18.310+|| W115: CoreDump: Writing minidump to C:\Users\enty\AppData\Local\Temp\vmware-enty\v2v_converter.dmp
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff7d9fb0000 size 0x0x003b4000
2022-06-10T03:08:18.429+|| I125: checksum 0x003c002a timestamp 0x618a2587
2022-06-10T03:08:18.429+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\V2V_Converter.exe
2022-06-10T03:08:18.429+|| I125: file version 9.0.1.268
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff900210000 size 0x0x001f5000
2022-06-10T03:08:18.429+|| I125: checksum 0x001f2aa7 timestamp 0xe7a22463
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\ntdll.dll
2022-06-10T03:08:18.429+|| I125: file version 6.2.19041.1110
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8ff310000 size 0x0x000bd000
2022-06-10T03:08:18.429+|| I125: checksum 0x000c5287 timestamp 0x92f57b1a
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\kernel32.dll
2022-06-10T03:08:18.429+|| I125: file version 6.2.19041.1023
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8fd9e0000 size 0x0x002c9000
2022-06-10T03:08:18.429+|| I125: checksum 0x002cc63d timestamp 0x4809adf2
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\KERNELBASE.dll
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8fe980000 size 0x0x001a0000
2022-06-10T03:08:18.429+|| I125: checksum 0x001a329c timestamp 0xefa6b327
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\user32.dll
2022-06-10T03:08:18.429+|| I125: file version 6.2.19041.906
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8fdcb0000 size 0x0x00022000
2022-06-10T03:08:18.429+|| I125: checksum 0x0002142c timestamp 0x0dcd0213
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\win32u.dll
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8cac90000 size 0x0x000f1000
2022-06-10T03:08:18.429+|| I125: checksum 0000000000 timestamp 0x5bb81865
2022-06-10T03:08:18.429+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\aws-cpp-sdk-core.dll
2022-06-10T03:08:18.429+|| I125: file version 0.0.0.0
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8bd4d0000 size 0x0x00356000
2022-06-10T03:08:18.429+|| I125: checksum 0000000000 timestamp 0x5bb81b8f
2022-06-10T03:08:18.429+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\aws-cpp-sdk-s3.dll
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff894d60000 size 0x0x00bd4000
2022-06-10T03:08:18.429+|| I125: checksum 0000000000 timestamp 0x5bb81ede
2022-06-10T03:08:18.429+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\aws-cpp-sdk-ec2.dll
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff9000c0000 size 0x0x0002a000
2022-06-10T03:08:18.429+|| I125: checksum 0x0002c658 timestamp 0xa19db164
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\gdi32.dll
2022-06-10T03:08:18.429+|| I125: file version 6.2.19041.746
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8fdf90000 size 0x0x0010b000
2022-06-10T03:08:18.429+|| I125: checksum 0x00107087 timestamp 0xb24bb404
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\gdi32full.dll
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8fe150000 size 0x0x0009d000
2022-06-10T03:08:18.429+|| I125: checksum 0x0009b039 timestamp 0x39255ccf
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\msvcp_win.dll
2022-06-10T03:08:18.429+|| I125: file version 6.2.19041.789
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8fdd30000 size 0x0x00100000
2022-06-10T03:08:18.429+|| I125: checksum 0x00103e56 timestamp 0x2bd748bf
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\ucrtbase.dll
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff8febc0000 size 0x0x0073f000
2022-06-10T03:08:18.429+|| I125: checksum 0x0074f5f1 timestamp 0x6e808d96
2022-06-10T03:08:18.429+|| I125: image file C:\Windows\System32\shell32.dll
2022-06-10T03:08:18.429+|| I125: CoreDump: including module base 0x0x7ff9000f0000 size 0x0x000ac000
2022-06-10T03:08:18.429+|| I125: checksum 0x000b05cc timestamp 0x1bfdec59
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\advapi32.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.1052
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fff50000 size 0x0x0009e000
2022-06-10T03:08:18.430+|| I125: checksum 0x0009e85d timestamp 0x564f9f39
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\msvcrt.dll
2022-06-10T03:08:18.430+|| I125: file version 7.0.19041.546
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8bd130000 size 0x0x003a0000
2022-06-10T03:08:18.430+|| I125: checksum 0000000000 timestamp 0x5bb81bc2
2022-06-10T03:08:18.430+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\aws-cpp-sdk-iam.dll
2022-06-10T03:08:18.430+|| I125: file version 0.0.0.0
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8feb20000 size 0x0x0009b000
2022-06-10T03:08:18.430+|| I125: checksum 0x000a578f timestamp 0x4782ccda
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\sechost.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.906
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff895c30000 size 0x0x005bd000
2022-06-10T03:08:18.430+|| I125: checksum 0x005c1105 timestamp 0x57c08974
2022-06-10T03:08:18.430+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\cpprest140_2_9.dll
2022-06-10T03:08:18.430+|| I125: file version 2.9.0.0
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe530000 size 0x0x00055000
2022-06-10T03:08:18.430+|| I125: checksum 0x0006123a timestamp 0xe6eb9927
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\shlwapi.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.1023
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe850000 size 0x0x0012a000
2022-06-10T03:08:18.430+|| I125: checksum 0x00133703 timestamp 0x16587408
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\rpcrt4.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.1081
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe6c0000 size 0x0x0012a000
2022-06-10T03:08:18.430+|| I125: checksum 0x00134633 timestamp 0x8c6c47c7
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\ole32.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.746
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ffb70000 size 0x0x0006b000
2022-06-10T03:08:18.430+|| I125: checksum 0x0006cf4b timestamp 0xaff3315b
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\ws2_32.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.546
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ffbe0000 size 0x0x00355000
2022-06-10T03:08:18.430+|| I125: checksum 0x00365c54 timestamp 0x473ce9d1
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\combase.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fd9b0000 size 0x0x00027000
2022-06-10T03:08:18.430+|| I125: checksum 0x00029837 timestamp 0x5eccdefc
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\bcrypt.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fde30000 size 0x0x0015f000
2022-06-10T03:08:18.430+|| I125: checksum 0x00167de0 timestamp 0xf5a52044
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\crypt32.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.844
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff88ed20000 size 0x0x01b63000
2022-06-10T03:08:18.430+|| I125: checksum 0000000000 timestamp 0x5f100b49
2022-06-10T03:08:18.430+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\gsoap.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ffff0000 size 0x0x000cd000
2022-06-10T03:08:18.430+|| I125: checksum 0x000d0679 timestamp 0x61567b6b
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\oleaut32.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.985
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ed310000 size 0x0x0005c000
2022-06-10T03:08:18.430+|| I125: checksum 0000000000 timestamp 0x5929a095
2022-06-10T03:08:18.430+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\SSLEAY32MD.dll
2022-06-10T03:08:18.430+|| I125: file version 1.0.2.12
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8bcf10000 size 0x0x00212000
2022-06-10T03:08:18.430+|| I125: checksum 0000000000 timestamp 0x5929a08d
2022-06-10T03:08:18.430+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\LIBEAY32MD.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff894a10000 size 0x0x00343000
2022-06-10T03:08:18.430+|| I125: checksum 0x0033e166 timestamp 0x5af04a9c
2022-06-10T03:08:18.430+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\wastorage.dll
2022-06-10T03:08:18.430+|| I125: file version 4.0.0.0
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8e2220000 size 0x0x0056a000
2022-06-10T03:08:18.430+|| I125: checksum 0x0057089d timestamp 0x6041aa14
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\mfc140u.dll
2022-06-10T03:08:18.430+|| I125: file version 14.28.29913.0
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f5480000 size 0x0x0001d000
2022-06-10T03:08:18.430+|| I125: checksum 0x00022aaf timestamp 0xbaf5f9a3
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\mpr.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff9001a0000 size 0x0x00030000
2022-06-10T03:08:18.430+|| I125: checksum 0x00033d33 timestamp 0x3a0e9944
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\imm32.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ed940000 size 0x0x0001b000
2022-06-10T03:08:18.430+|| I125: checksum 0x00020b8e timestamp 0x612d9159
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\VCRUNTIME140.dll
2022-06-10T03:08:18.430+|| I125: file version 14.29.30135.0
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ea800000 size 0x0x0008d000
2022-06-10T03:08:18.430+|| I125: checksum 0x0008d891 timestamp 0x612d915a
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\msvcp140.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8e7cf0000 size 0x0x0029a000
2022-06-10T03:08:18.430+|| I125: checksum 0x0029fa3c timestamp 0xdb2b08ef
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll
2022-06-10T03:08:18.430+|| I125: file version 6.10.19041.1110
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f6830000 size 0x0x0000a000
2022-06-10T03:08:18.430+|| I125: checksum 0x0000d776 timestamp 0x14531102
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\version.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fd850000 size 0x0x0002e000
2022-06-10T03:08:18.430+|| I125: checksum 0x000362d0 timestamp 0xfa786637
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\userenv.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.572
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f6fe0000 size 0x0x0010a000
2022-06-10T03:08:18.430+|| I125: checksum 0x0010e249 timestamp 0x7a57eba4
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\winhttp.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.1110
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8e76d0000 size 0x0x0000f000
2022-06-10T03:08:18.430+|| I125: checksum 0x0000d5a5 timestamp 0xb6ad83e7
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\httpapi.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ed3f0000 size 0x0x004dd000
2022-06-10T03:08:18.430+|| I125: checksum 0x004d603a timestamp 0xa4a6888d
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\wininet.dll
2022-06-10T03:08:18.430+|| I125: file version 11.0.19041.1052
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8d54a0000 size 0x0x0004e000
2022-06-10T03:08:18.430+|| I125: checksum 0x0005ab41 timestamp 0x612d9159
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\CONCRT140.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f4750000 size 0x0x0019e000
2022-06-10T03:08:18.430+|| I125: checksum 0x001a1a7f timestamp 0x12630cfb
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\vssapi.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8e8410000 size 0x0x0000c000
2022-06-10T03:08:18.430+|| I125: checksum 0x00015d37 timestamp 0x612d915e
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\VCRUNTIME140_1.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f7b20000 size 0x0x00036000
2022-06-10T03:08:18.430+|| I125: checksum 0x00039720 timestamp 0x1bfb31ad
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\xmllite.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fb380000 size 0x0x0009e000
2022-06-10T03:08:18.430+|| I125: checksum 0x0009cf45 timestamp 0x4450263d
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\uxtheme.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f4730000 size 0x0x00018000
2022-06-10T03:08:18.430+|| I125: checksum 0x0001f894 timestamp 0x9a630424
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\vsstrace.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fd660000 size 0x0x0000a000
2022-06-10T03:08:18.430+|| I125: checksum 0x0000675d timestamp 0x821d1564
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\dpapi.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe1f0000 size 0x0x00083000
2022-06-10T03:08:18.430+|| I125: checksum 0x0008abd1 timestamp 0xfb9f1cda
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\bcryptprimitives.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fb860000 size 0x0x00012000
2022-06-10T03:08:18.430+|| I125: checksum 0x0001a722 timestamp 0xf0713fcd
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\kernel.appcore.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f4100000 size 0x0x00028000
2022-06-10T03:08:18.430+|| I125: checksum 0x000255e6 timestamp 0x1be246ba
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\wbem\wmiutils.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f4990000 size 0x0x00092000
2022-06-10T03:08:18.430+|| I125: checksum 0x00094916 timestamp 0x79fb52f2
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\wbemcomn.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe280000 size 0x0x00115000
2022-06-10T03:08:18.430+|| I125: checksum 0x001194a1 timestamp 0xf0f0b08e
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\msctf.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ebcf0000 size 0x0x000f9000
2022-06-10T03:08:18.430+|| I125: checksum 0x000fe886 timestamp 0x4a8c4bbf
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\textinputframework.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fac50000 size 0x0x0035e000
2022-06-10T03:08:18.430+|| I125: checksum 0x00363804 timestamp 0xce358de3
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\CoreUIComponents.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fb0c0000 size 0x0x000f2000
2022-06-10T03:08:18.430+|| I125: checksum 0x000f8399 timestamp 0xd3dfbbe6
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\CoreMessaging.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe610000 size 0x0x000ae000
2022-06-10T03:08:18.430+|| I125: checksum 0x000b3769 timestamp 0xa38af655
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\SHCore.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fc640000 size 0x0x00033000
2022-06-10T03:08:18.430+|| I125: checksum 0x00038797 timestamp 0x3d60ad04
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\ntmarta.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fa9f0000 size 0x0x00154000
2022-06-10T03:08:18.430+|| I125: checksum 0x0015ee83 timestamp 0xa7c290cc
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\WinTypes.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8d0d20000 size 0x0x00095000
2022-06-10T03:08:18.430+|| I125: checksum 0x000995b8 timestamp 0x3edb1f69
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\duser.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8ee7c0000 size 0x0x0000d000
2022-06-10T03:08:18.430+|| I125: checksum 0x0001224e timestamp 0xc42be918
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\atlthunk.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8e95c0000 size 0x0x000ac000
2022-06-10T03:08:18.430+|| I125: checksum 0x000b00c3 timestamp 0xf53222a7
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\TextShaping.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8eace0000 size 0x0x00066000
2022-06-10T03:08:18.430+|| I125: checksum 0x0006cb24 timestamp 0x24cdd509
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\oleacc.dll
2022-06-10T03:08:18.430+|| I125: file version 7.2.19041.746
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fb570000 size 0x0x0002f000
2022-06-10T03:08:18.430+|| I125: checksum 0x0003836d timestamp 0x7ecc0a11
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\dwmapi.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe3a0000 size 0x0x000da000
2022-06-10T03:08:18.430+|| I125: checksum 0x000d8871 timestamp 0x26a1dda9
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\comdlg32.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fe480000 size 0x0x000a9000
2022-06-10T03:08:18.430+|| I125: checksum 0x000ac808 timestamp 0xdb9f728a
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\clbcatq.dll
2022-06-10T03:08:18.430+|| I125: file version 2001.12.10941.16384
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fba60000 size 0x0x00791000
2022-06-10T03:08:18.430+|| I125: checksum 0x007a5dff timestamp 0x9fa5b547
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\windows.storage.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fd210000 size 0x0x0002c000
2022-06-10T03:08:18.430+|| I125: checksum 0x0002efab timestamp 0x409dec87
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\wldp.dll
2022-06-10T03:08:18.430+|| I125: file version 6.2.19041.662
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8e8930000 size 0x0x00024000
2022-06-10T03:08:18.430+|| I125: checksum 0x00025ad7 timestamp 0xbe357357
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\edputil.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f3ba0000 size 0x0x001b4000
2022-06-10T03:08:18.430+|| I125: checksum 0x001b942b timestamp 0x691f6c30
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\WindowsCodecs.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fd890000 size 0x0x0001f000
2022-06-10T03:08:18.430+|| I125: checksum 0x0001fffe timestamp 0x793b0534
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\profapi.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8fdce0000 size 0x0x0004e000
2022-06-10T03:08:18.430+|| I125: checksum 0x00053722 timestamp 0x44bdc47e
2022-06-10T03:08:18.430+|| I125: image file C:\Windows\System32\cfgmgr32.dll
2022-06-10T03:08:18.430+|| I125: CoreDump: including module base 0x0x7ff8f9550000 size 0x0x000f6000
2022-06-10T03:08:18.431+|| I125: checksum 0x000fe2f8 timestamp 0x5f3c9ace
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\propsys.dll
2022-06-10T03:08:18.431+|| I125: file version 7.0.19041.1023
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8e8ba0000 size 0x0x0007d000
2022-06-10T03:08:18.431+|| I125: checksum 0x00080ba4 timestamp 0xae07234c
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\ntshrui.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.844
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fd810000 size 0x0x00031000
2022-06-10T03:08:18.431+|| I125: checksum 0x0003b18c timestamp 0xccc94890
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\sspicli.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.906
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f5450000 size 0x0x00028000
2022-06-10T03:08:18.431+|| I125: checksum 0x00022ff5 timestamp 0x4e6b0a76
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\srvcli.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.546
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f4f00000 size 0x0x00012000
2022-06-10T03:08:18.431+|| I125: checksum 0x0001baa7 timestamp 0x31063a34
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\cscapi.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8e8c20000 size 0x0x00062000
2022-06-10T03:08:18.431+|| I125: checksum 0x000672bf timestamp 0xe4becc03
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\Windows.FileExplorer.Common.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.867
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8efb20000 size 0x0x002b0000
2022-06-10T03:08:18.431+|| I125: checksum 0x002ae1a7 timestamp 0x39f20fa0
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\iertutil.dll
2022-06-10T03:08:18.431+|| I125: file version 11.0.19041.1081
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8dc450000 size 0x0x000a6000
2022-06-10T03:08:18.431+|| I125: checksum 0x000b132f timestamp 0xda4754f3
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\StructuredQuery.dll
2022-06-10T03:08:18.431+|| I125: file version 7.0.19041.867
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8de340000 size 0x0x00066000
2022-06-10T03:08:18.431+|| I125: checksum 0x0006fcb4 timestamp 0x6f372c09
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\thumbcache.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.746
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f9010000 size 0x0x000a0000
2022-06-10T03:08:18.431+|| I125: checksum 0x0009fdbf timestamp 0x95a353b2
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\policymanager.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.1023
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fca40000 size 0x0x0008a000
2022-06-10T03:08:18.431+|| I125: checksum 0x00089bc9 timestamp 0xf390ead1
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\msvcp110_win.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8e3110000 size 0x0x0003e000
2022-06-10T03:08:18.431+|| I125: checksum 0x0003fcc0 timestamp 0x9e33b256
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\dataexchange.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f9db0000 size 0x0x00264000
2022-06-10T03:08:18.431+|| I125: checksum 0x002692a8 timestamp 0xfc177b9d
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\d3d11.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fa480000 size 0x0x001e6000
2022-06-10T03:08:18.431+|| I125: checksum 0x001eda05 timestamp 0x662b586c
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\dcomp.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fc240000 size 0x0x000f4000
2022-06-10T03:08:18.431+|| I125: checksum 0x000f36a2 timestamp 0xfb58b4ca
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\dxgi.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.964
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8eec80000 size 0x0x00146000
2022-06-10T03:08:18.431+|| I125: checksum 0x001496e0 timestamp 0x0e723829
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\Windows.StateRepositoryPS.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f3d60000 size 0x0x00201000
2022-06-10T03:08:18.431+|| I125: checksum 0x00206dc9 timestamp 0x3c7d7571
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\twinapi.appcore.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8d6930000 size 0x0x000c6000
2022-06-10T03:08:18.431+|| I125: checksum 0x000c2523 timestamp 0x7f1c6c29
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\Windows.Storage.Search.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8e9500000 size 0x0x00023000
2022-06-10T03:08:18.431+|| I125: checksum 0x0001d12e timestamp 0xadcd83c9
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\cldapi.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.1081
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f4a30000 size 0x0x0000b000
2022-06-10T03:08:18.431+|| I125: checksum 0x00013a5d timestamp 0x2ea9f33d
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\fltLib.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fb1c0000 size 0x0x00090000
2022-06-10T03:08:18.431+|| I125: checksum 0x0009350d timestamp 0xdc01baa3
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\apphelp.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.928
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8d88b0000 size 0x0x000ac000
2022-06-10T03:08:18.431+|| I125: checksum 0x000a95df timestamp 0x6141cc65
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files (x86)\Common Files\Adobe\CoreSyncExtension\CoreSync_x64.dll
2022-06-10T03:08:18.431+|| I125: file version 4.21.1.1
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8d7bb0000 size 0x0x0013e000
2022-06-10T03:08:18.431+|| I125: checksum 0x0014b451 timestamp 0x5dcb673d
2022-06-10T03:08:18.431+|| I125: image file C:\Users\enty\AppData\Local\115Chrome\Application\24.0.2.2\backup_shell_x64.dll
2022-06-10T03:08:18.431+|| I125: file version 1.0.0.17
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ea200000 size 0x0x00037000
2022-06-10T03:08:18.431+|| I125: checksum 0x000392ec timestamp 0x75e918f4
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\EhStorShell.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ff4c0000 size 0x0x00469000
2022-06-10T03:08:18.431+|| I125: checksum 0x0047723b timestamp 0x3622af01
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\setupapi.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8d4530000 size 0x0x000cd000
2022-06-10T03:08:18.431+|| I125: checksum 0x000d4b49 timestamp 0x8c31e680
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\cscui.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8afbe0000 size 0x0x001aa000
2022-06-10T03:08:18.431+|| I125: checksum 0x001b027d timestamp 0x5cee3b9f
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\vixDiskLib.dll
2022-06-10T03:08:18.431+|| I125: file version 6.5.4.38226
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x747c0000 size 0x0x000a3000
2022-06-10T03:08:18.431+|| I125: checksum 0x000aba65 timestamp 0x5db2744b
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_08e1c10da83fbc83\msvcr90.dll
2022-06-10T03:08:18.431+|| I125: file version 9.0.30729.9625
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8946c0000 size 0x0x00343000
2022-06-10T03:08:18.431+|| I125: checksum 0x0034862b timestamp 0x587d83ab
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\vixMntapi.dll
2022-06-10T03:08:18.431+|| I125: file version 8.6.2.333
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x746e0000 size 0x0x000d3000
2022-06-10T03:08:18.431+|| I125: checksum 0x000d501a timestamp 0x5db2744f
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_08e1c10da83fbc83\msvcp90.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ea890000 size 0x0x00018000
2022-06-10T03:08:18.431+|| I125: checksum 0x00015f5e timestamp 0x1f1158d3
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\netapi32.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fce10000 size 0x0x0000c000
2022-06-10T03:08:18.431+|| I125: checksum 0x00012761 timestamp 0xfcf57d1b
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\netutils.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x74490000 size 0x0x00246000
2022-06-10T03:08:18.431+|| I125: checksum 0x0024d6d1 timestamp 0x5c81d82d
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\libeay32.dll
2022-06-10T03:08:18.431+|| I125: file version 1.0.2.18
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ce710000 size 0x0x0005e000
2022-06-10T03:08:18.431+|| I125: checksum 0x000618ee timestamp 0x5c81d83a
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\ssleay32.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fd250000 size 0x0x00018000
2022-06-10T03:08:18.431+|| I125: checksum 0x0001d2be timestamp 0x04d97ae6
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\cryptsp.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fc9b0000 size 0x0x00034000
2022-06-10T03:08:18.431+|| I125: checksum 0x0003ccde timestamp 0xa9b3ef3b
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\rsaenh.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.1052
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fd170000 size 0x0x0000c000
2022-06-10T03:08:18.431+|| I125: checksum 0x00014a16 timestamp 0x28e89a43
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\CRYPTBASE.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8cabf0000 size 0x0x00096000
2022-06-10T03:08:18.431+|| I125: checksum 0x0009421e timestamp 0x5cee3bca
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\vixDiskLibVim.dll
2022-06-10T03:08:18.431+|| I125: file version 6.5.0.38226
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff894100000 size 0x0x005b1000
2022-06-10T03:08:18.431+|| I125: checksum 0x005a562a timestamp 0x5cee3ab4
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\gvmomi.dll
2022-06-10T03:08:18.431+|| I125: file version 12.0.0.38226
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x180000000 size 0x0x0018f000
2022-06-10T03:08:18.431+|| I125: checksum 0x001961ae timestamp 0x58f9814d
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\glib-2.0.dll
2022-06-10T03:08:18.431+|| I125: file version 2.42.2.0
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8bce90000 size 0x0x0007e000
2022-06-10T03:08:18.431+|| I125: checksum 0x0008c0fd timestamp 0x5cb44a91
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\libcurl.dll
2022-06-10T03:08:18.431+|| I125: file version 7.64.1.0
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f20a0000 size 0x0x00027000
2022-06-10T03:08:18.431+|| I125: checksum 0x0002d89c timestamp 0xb8ca2d77
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\winmm.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ee800000 size 0x0x0001e000
2022-06-10T03:08:18.431+|| I125: checksum 0x0002cfc7 timestamp 0x5303b6ad
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\intl.dll
2022-06-10T03:08:18.431+|| I125: file version 0.14.6.3
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ff450000 size 0x0x00056000
2022-06-10T03:08:18.431+|| I125: checksum 0x0005eb47 timestamp 0x05a1ccfb
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\Wldap32.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ff300000 size 0x0x00008000
2022-06-10T03:08:18.431+|| I125: checksum 0x00010d20 timestamp 0x8c27fee9
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\normaliz.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff899f70000 size 0x0x00123000
2022-06-10T03:08:18.431+|| I125: checksum 0x00123188 timestamp 0x4f9830e0
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\iconv.dll
2022-06-10T03:08:18.431+|| I125: file version 1.9.0.2
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x2e32fbe0000 size 0x0x0005d000
2022-06-10T03:08:18.431+|| I125: checksum 0x00061c84 timestamp 0x58f9815a
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\gobject-2.0.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x2e331400000 size 0x0x00238000
2022-06-10T03:08:18.431+|| I125: checksum 0x0023a0cf timestamp 0x5c51f184
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\StarWind Software\StarWind V2V Converter\lib\libxml2.dll
2022-06-10T03:08:18.431+|| I125: file version 2.9.9.0
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ece40000 size 0x0x00009000
2022-06-10T03:08:18.431+|| I125: checksum 0x0001038f timestamp 0x56e9f92a
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\wsock32.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8e6d80000 size 0x0x0000c000
2022-06-10T03:08:18.431+|| I125: checksum 0x0000c444 timestamp 0x7aec0e44
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\secur32.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fcd00000 size 0x0x0003b000
2022-06-10T03:08:18.431+|| I125: checksum 0x0003ecbd timestamp 0xcf9a121a
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\IPHLPAPI.DLL
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fcff0000 size 0x0x0006a000
2022-06-10T03:08:18.431+|| I125: checksum 0x00071df1 timestamp 0xf42c9c21
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\mswsock.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fff40000 size 0x0x00008000
2022-06-10T03:08:18.431+|| I125: checksum 0x000117c5 timestamp 0xaa9c8581
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\nsi.dll
2022-06-10T03:08:18.431+|| I125: file version 6.2.19041.610
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f6dd0000 size 0x0x00017000
2022-06-10T03:08:18.431+|| I125: checksum 0x00014e4a timestamp 0xc962e034
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\dhcpcsvc6.DLL
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f6db0000 size 0x0x0001d000
2022-06-10T03:08:18.431+|| I125: checksum 0x0002666a timestamp 0x1c1d619d
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\dhcpcsvc.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8fcd40000 size 0x0x000cc000
2022-06-10T03:08:18.431+|| I125: checksum 0x000d5511 timestamp 0x72e5fb72
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\dnsapi.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ee170000 size 0x0x00017000
2022-06-10T03:08:18.431+|| I125: checksum 0x00020a62 timestamp 0x818f19bf
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\NapiNSP.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8ee150000 size 0x0x0001b000
2022-06-10T03:08:18.431+|| I125: checksum 0x0001a9c0 timestamp 0xd2935d6a
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\pnrpnsp.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f8910000 size 0x0x00015000
2022-06-10T03:08:18.431+|| I125: checksum 0x0001ddee timestamp 0xeee9ca5c
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\wshbth.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f92c0000 size 0x0x0001d000
2022-06-10T03:08:18.431+|| I125: checksum 0x0002543e timestamp 0x1e35a046
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\nlaapi.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f4b50000 size 0x0x00012000
2022-06-10T03:08:18.431+|| I125: checksum 0x000146d6 timestamp 0x5cf5a6d9
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\winrnr.dll
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x75a30000 size 0x0x00026000
2022-06-10T03:08:18.431+|| I125: checksum 0x0002a619 timestamp 0x55cbcce5
2022-06-10T03:08:18.431+|| I125: image file C:\Program Files\Bonjour\mdnsNSP.dll
2022-06-10T03:08:18.431+|| I125: file version 3.1.0.1
2022-06-10T03:08:18.431+|| I125: CoreDump: including module base 0x0x7ff8f5870000 size 0x0x001e4000
2022-06-10T03:08:18.431+|| I125: checksum 0x001d0396 timestamp 0x7c197411
2022-06-10T03:08:18.431+|| I125: image file C:\Windows\System32\dbghelp.dll
2022-06-10T03:08:18.432+|| I125: CoreDump: including module base 0x0x7ff8edf20000 size 0x0x0002c000
2022-06-10T03:08:18.432+|| I125: checksum 0x0002adac timestamp 0x225c0d3d
2022-06-10T03:08:18.432+|| I125: image file C:\Windows\System32\dbgcore.dll
2022-06-10T03:08:18.432+|| I125: file version 6.2.19041.789
2022-06-10T03:08:18.432+|| I125: CoreDump: including module base 0x0x7ff8ff4b0000 size 0x0x00008000
2022-06-10T03:08:18.432+|| I125: checksum 0x0000503c timestamp 0x0f828c32
2022-06-10T03:08:18.432+|| I125: image file C:\Windows\System32\psapi.dll
2022-06-10T03:08:18.432+|| I125: file version 6.2.19041.546
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 8376
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 18720
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 13552
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 18688
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 2856
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 10752
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 3668
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 16888
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 4736
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 2956
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 16732
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 9764
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 18476
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 14928
2022-06-10T03:08:18.432+|| I125: CoreDump: Including thread 3272
2022-06-10T03:08:18.480+|| I125: Msg_Post: Error
2022-06-10T03:08:18.480+|| I125: [msg.log.error.unrecoverable] VMware Virtual Disk Development Kit unrecoverable error: (vthread-4)
2022-06-10T03:08:18.480+|| I125+ NOT_IMPLEMENTED d:/build/ob/bora-13861102/bora/lib/unicode/unicodeSimpleBase.c:741
2022-06-10T03:08:18.480+|| I125: [msg.panic.haveLog] A log file is available in "C:\Users\enty\AppData\Local\Temp\vmware-enty\vixDiskLib-18684.log".
2022-06-10T03:08:18.480+|| I125: [msg.panic.requestSupport.withoutLog] You can request support.
2022-06-10T03:08:18.480+|| I125: [msg.panic.requestSupport.vmSupport.vmx86]
2022-06-10T03:08:18.480+|| I125+ To collect data to submit to VMware technical support, run "vm-support".
2022-06-10T03:08:18.480+|| I125: [msg.panic.response] We will respond on the basis of your support entitlement.
2022-06-10T03:08:18.480+|| I125: ----------------------------------------
enty
Thu Jun 09, 2022 7:26 pm
well I changed the distination image to another disk, it works...
Fri Jun 10, 2022 9:46 am
Good to know that you fixed it!
Were there any non-ASCII symbols in destination name?
