StarWind P2V Migrator
istinson
Thu May 26, 2022 6:21 pm
Wondering if there is a way to kick off the conversion/migration process via CLI(PowerShell Preferably) or in Task Scheduler
istinson
Tue May 31, 2022 9:22 pm
yaroslav (staff) wrote:Check this out https://www.starwindsoftware.com/v2v-he ... rface.html
Does the CLI only support V2V?
As the documentation container "StarWind V2V Converter Help : Command Line Interface" referencing v2v
Currently getting an error "Invalid parameter. Must be in_file_name."
Tue May 31, 2022 9:55 pm
Can I have the command you are running, please?
istinson
Tue May 31, 2022 10:08 pm
yaroslav (staff) wrote:Can I have the command you are running, please?
V2V_ConverterConsole.exe -c "C:\Program Files\StarWind Software\StarWind V2V Converter\SWP2V-350test.cfg"
contents of .cfg file
#Convert local physical disk 0 to remote VHDX:
in_host_type=win
in_host_address=*********
in_host_username=<username>
in_host_password=<password>
in_file_name="D:\Hyper-V\Virtual Hard Disks\D401IT001.vhdx"
out_host_type=local
out_host_address=*********
out_host_username=<username>
out_host_password=<password>
out_file_type=ft_vhdx_thick
out_file_name="D:\Hyper-V\Virtual Hard Disks\test01.vhdx"
Tue May 31, 2022 10:23 pm
You are not converting the physical disk but a VHDX. Please see the samples at the end of the KB https://www.starwindsoftware.com/v2v-he ... rface.html.
istinson
Wed Jun 01, 2022 12:31 pm
I see my mistake please see the updated attached, I changed the output file type to an (raw).iso, Still yielding the same error.
in_host_type=win
in_host_address="S401PXE02.*******.com"
in_host_username="********"
in_host_password="********"
out_host_type=win
out_host_address="S401PXE02.**********.com"
out_host_username="*******"
out_host_password="******"
out_file_type=ft_raw
out_file_name="D:\Hyper-V\Virtual Hard Disks\test01.iso"
Wed Jun 01, 2022 12:47 pm
Please note that it is not about the file extension. You are converting a VHDX file to another VHDX file. This is not P2V migration this is V2V conversion.
As suggested earlier, you need to refer to the Samples section of https://www.starwindsoftware.com/v2v-he ... rface.html
V2V_ConverterConsole.exe convert in_file_name="c:\test\disk.img" out_file_name="d:\disk.vmdk" out_file_type=ft_vmdk_ws_thick
This is what the local V2V conversion should look like.
istinson
Wed Jun 01, 2022 1:10 pm
yaroslav (staff) wrote:Please note that it is not about the file extension. You are converting a VHDX file to another VHDX file. This is not P2V migration this is V2V conversion.
Ok i see, But this isn't utilizing the configuration file at all
Would I be better off inputting all parameters manually into the CLI rather than trying to call the configuration file?
Because the parameters you gave me were just a broken down version of what I was trying to do with the configuration file.
Thu Jun 02, 2022 10:18 pm
You could use a file but make sure to set it up properly.
Bad example, sorry... You are referring to the VHDX in your file. The question is what you are trying to convert: local or a physical volume?
