Change Password via Powershell
janderson133
Wed Apr 27, 2022 12:19 am
I'm trying to change the password via powershell per this thread: https://forums.starwindsoftware.com/vie ... ord#p28708
The thread states the format of the password:
raw format: "##" + ToBase64(MD5(password))
original: "##evVRsIJtRmAEEd2sCslZDg==" from "starwind"
My understanding of MD5 is that it will always produce a 32 character string and so it can never be as short as what is referenced. My output is always much longer:
MD5 hash: 7af551b0826d46600411ddac0ac9590e
New server hash: ##NwBhAGYANQA1ADEAYgAwADgAMgA2AGQANAA2ADYAMAAwADQAMQAxAGQAZABhAGMAMABhAGMAOQA1ADkAMABlAA==
    $password="starwind"
     $md5 = new-object -TypeName System.Security.Cryptography.MD5CryptoServiceProvider
     $utf8 = new-object -TypeName System.Text.UTF8Encoding
     $hash = [System.BitConverter]::ToString($md5.ComputeHash($utf8.GetBytes($password)))
     $hash = $hash.ToLower() -replace '-', ''
     write-host "MD5 hash: " $hash
     $StringBytes = [System.Text.Encoding]::Unicode.GetBytes($hash)
     # Encode string content to Base64 string
     $newpasswordhash = "##" + [Convert]::ToBase64String($StringBytes)
     write-host "New server hash: " $newpasswordhash
Thanks - Jeff
Sat Apr 30, 2022 12:44 am
You have generated the MD5HASH value from starwind. Then, you have been using the hex value to generate the ToBase64 hash.
Try the following path Password string value -> md5 = 128 bit hash in hex format -> from hex value to base64 value.
janderson133
Wed May 04, 2022 4:32 am
Thanks for the pointer and this code seems to work:
$hash = $md5.ComputeHash($utf8.GetBytes($password))
# Encode binary MD5 content to Base64 string
$newpasswordhash = "##" + [Convert]::ToBase64String($hash)
Wed May 04, 2022 1:33 pm
Good to know that it works. Please try typing the non-encrypted word to confirm it working.
