Conversion Error
PuserS
Tue Mar 29, 2022 6:33 pm
I am trying to virtualize a local physical disk. I get the following error. I was able to convert the disk with disk2vhd but when I tried to convert that local file I get Error number 2 below.
Error 1
3/29 11:13:33.320 33f4 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
3/29 11:13:36.408 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
3/29 11:13:44.376 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelect
3/29 11:13:52.192 33f4 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eTypeP2V
3/29 11:13:53.912 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
3/29 11:13:55.280 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
3/29 11:14:00.223 33f4 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eVolumeSelectVM
3/29 11:14:09.144 33f4 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eTypeP2V
3/29 11:14:11.496 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
3/29 11:14:17.592 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
3/29 11:14:19.768 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
3/29 11:14:23.135 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsVMware
3/29 11:14:25.968 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsESXI
3/29 11:14:28.208 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
3/29 11:14:39.143 33f4 Facility ???INFO: CPPOutputFile::onNext: Out path: F:\p2v\PSPL-2766.vmdk, Out format 13
3/29 11:14:39.143 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
3/29 11:14:39.149 36b0 Facility ???INFO: CPPConverting::Convert: InConvertType: 2, OutConvertType: 4
3/29 11:14:39.150 36b0 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 0, pathOutput: F:\p2v\PSPL-2766.vmdk
3/29 11:14:39.150 36b0 Facility ???INFO: P2V::CreateInputImage: path 0
3/29 11:14:39.150 36b0 Facility ???INFO: P2V::CreateInputImage: Size 0 - 500107862016, BytesPerSector - 512
3/29 11:15:35.456 36b0 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
3/29 11:15:36.915 36b0 Facility ???INFO: VMwareFile::NewFile: sFileName - F:\p2v\PSPL-2766.vmdk
3/29 11:15:36.915 36b0 Facility ???INFO: VMwareFile::NewFile: SectorType - 976773168
3/29 11:15:36.915 36b0 Facility ???INFO: VMwareFile::NewFile: EVMDKCreateType - 1
3/29 11:15:36.915 36b0 Facility ???INFO: VMwareFile::NewFile: EVMDKAdapterType - 0
3/29 11:15:36.915 36b0 Facility ???INFO: VMwareFile::NewFile: createType is fail - 1
3/29 11:15:36.915 36b0 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 19
3/29 11:15:36.915 36b0 Facility ???ERROR: CPPConverting::Convert: FAILED
Error 2
3/29 14:32:19.336 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocation
3/29 14:32:24.088 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
3/29 14:33:28.816 33f4 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
3/29 14:33:31.495 33f4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputFile
3/29 14:33:31.495 33f4 Facility ???INFO: CPPInputFile::checkFile: Select file: F:\PSPL-2766.VHDX
3/29 14:33:31.495 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
3/29 14:33:31.495 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
3/29 14:33:31.495 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
3/29 14:33:31.495 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
3/29 14:33:31.495 33f4 Facility ???ERROR: CVHDXFile::ParseFile: Log header signature is fail - 0.
3/29 14:33:31.496 33f4 Facility ???INFO: CPPInputFile::checkFile: ParseFile: 2
3/29 14:33:37.208 33f4 Facility ???INFO: CPPInputFile::checkFile: Select file: F:\PSPL-2766.VHDX
3/29 14:33:37.208 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
3/29 14:33:37.208 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
3/29 14:33:37.208 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
3/29 14:33:37.208 33f4 Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
3/29 14:33:37.208 33f4 Facility ???ERROR: CVHDXFile::ParseFile: Log header signature is fail - 0.
3/29 14:33:37.208 33f4 Facility ???INFO: CPPInputFile::checkFile: ParseFile: 2
Wed Mar 30, 2022 11:50 am
Greetings,
Are you sure to have enough space on the destination device?
PuserS
Tue Apr 12, 2022 3:19 pm
Previously I had issues caused by the USB drive being FAT32. I have since formatted it to exfat. The Volume size is around 150GB. Target directory has 780GB free. I still get errors when trying to convert a vhd to vmdk and when trying to convert physical volume to vmdk.
Thu Apr 14, 2022 2:15 pm
Please try moving the disk to the local drive and try connecting it as a local file again.
