SAN & NAS plugin installation failed
bolivier
Thu Feb 10, 2022 3:51 pm
Hello
One minor error (already reported) when I tried to install the plugin, the field "VMware vCenter Server FQDN or IP address" only accept IP address. Minor but annoying.
my vCenter is a v7.0.3 (19234570).
When I try to install the plugin, it always fails after 31%, stating "StarWind vCenter Plugin deployment has failed. To troubleshoot the issue, please download and review the installation logs".
Any idea ?
Olivier
The log file:
logs_172.20.125.98_10_02_2022_15_55_37.zip
Plugin error log
(5.54 KiB) Downloaded 1028 times
Mon Feb 14, 2022 4:21 am
Greetings,
Thank you for your logs. We will investigate them in good order once I have the full set of logs. Could you kindly generate a support bundle for me, please?
dmytro (staff)
Mon Feb 14, 2022 1:25 pm
Hello bolivier,
I hope all is well.
Our developers are under investigating the cause of the error and we will inform once get the result.
It might help if you could clarify whether your account "administrator@vsphere.ne" is correct and it has the following privileges assigned:
- Extension.Register,
- Extension.Unregister,
- Extension.Update.
Thank you!
Product Manager
Cheers,
Product Manager, StarWind Virtual SAN
bolivier
Thu Feb 17, 2022 3:06 pm
The administrator@vsphere.ne was the account used for installation and it has the "administrator" role (see attached picture)
Capture d’écran 2022-02-17 160236.jpg (23.45 KiB) Viewed 13276 times
Thu Feb 17, 2022 3:20 pm
Thank you. Will keep you posted.
