VMDK_API_Wrapper::getSslThumbprint: Can't connect to server
simon.berg
Fri Jan 07, 2022 2:37 pm
Hi Guys
I'm getting this error when using the console version.
Any pointers or can we specify a parameter to ignore certificate errors?
1/7 15:38:53.922 fc8 Facility ???INFO: VMConverter::ESXIConverter::AddVirtualDisk: Attach random
1/7 15:38:54.089 fc8 Facility ???INFO: VMConverter::ESXIConverter::AddVirtualDisk: Finded SCSI_0 numLoc - 3
1/7 15:38:54.159 fc8 Facility ???INFO: VMConverter::ESXIConverter::AddVirtualDisk: attachDisk is 1
1/7 15:38:54.182 fc8 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore01] Windows2012R2/Windows2012R2_disk0.vmdk
1/7 15:38:54.182 fc8 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=56
1/7 15:38:54.182 fc8 Facility ???ERROR: VMDK_API_Wrapper::getSslThumbprint: Can't connect to server 'esx01.vm-mgmt.com', WinSock error - 10049.
1/7 15:38:54.182 fc8 Facility ???ERROR: ESXVmdk::ParseFile: sslThumbprint is empty
1/7 15:38:54.182 fc8 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
1/7 15:38:54.182 fc8 Facility ???ERROR: RunConsole: Error create output image - 1
simon.berg
Fri Jan 07, 2022 3:05 pm
I also tested with the UI both it also fails, but just with another error.
1/7 15:46:31.423 ca8 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore01] Windows2012R2/Windows2012R2_disk0.vmdk
1/7 15:46:31.423 ca8 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=56
1/7 15:46:31.427 ca8 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 43:39:51:FD:08:1A:19:B1:BC:46:85:4A:42:B4:E4:6E:DC:D0:C1:2B
1/7 15:47:13.589 ca8 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
1/7 15:47:13.589 ca8 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
1/7 15:47:13.589 ca8 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
1/7 15:47:13.589 ca8 Facility ???ERROR: CPPConverting::Convert: FAILED
simon.berg
Fri Jan 07, 2022 3:17 pm
I have port 80 and 443 open for my ESXi host.
But port 902 is not open.... is this required?
I use this software for a bit older ESXi environment and this is the only difference in the Network i can find.
Mon Jan 10, 2022 6:56 am
Greetings,
Looks like the V2V Converter cannot connect to the server. Try temporarily disabling the firewall OR move the file to the destination server and try V2V conversion of the local file.
simon.berg
Mon Jan 10, 2022 10:18 am
Hi yaroslav
Thank you for your reply.
I confirmed that the ports 80 and 443 is open to the host.
I'm converting a local .vhdx file on from my management server (Windows) to a thin provisioned disk on a specific VM on that specific host.
I also tried disabling my windows firewall on the management machine, but it did not change anything.
With the UI i can connect to the host then browse and select the vm and start the conversion, but that also fails.
Are you sure that port 80 and 443 is the only ports needed to be open for the VMware ESXi host?
simon.berg
Mon Jan 10, 2022 10:20 am
Hi yaroslav
Can i do something so the Starwind V2V converter will ignore certificate errors?
Mon Jan 10, 2022 12:13 pm
Greetings,
Please try copying it to the destination server and converting it as a local file, if possible.
simon.berg
Mon Jan 10, 2022 12:37 pm
What do you mean?
Copy my .vhdx file into my ESXi host data store and then try convert the .vhdx -> on my target vm in vmware?
simon.berg
Mon Jan 10, 2022 12:46 pm
Then it fails....
1/10 13:44:21.940 1b50 Facility ???INFO: CCommandLineManager::AddParametersForConvertCommand: in_file_name=[Datastore01] Windows2012R2_1/Windows2012R2_disk0.vhdx
1/10 13:44:21.940 1b50 Facility ???INFO: CCommandLineManager::AddParametersForConvertCommand: out_host_type=esx
1/10 13:44:21.940 1b50 Facility ???INFO: CCommandLineManager::AddParametersForConvertCommand: out_host_address=esx01.vm-mgmt.com
1/10 13:44:21.940 1b50 Facility ???INFO: CCommandLineManager::AddParametersForConvertCommand: out_host_username=<MASKED>
1/10 13:44:21.940 1b50 Facility ???INFO: CCommandLineManager::AddParametersForConvertCommand: out_file_name=[Datastore01] Windows2012R2/Windows2012R2_disk0.vmdk
1/10 13:44:21.940 1b50 Facility ???INFO: CCommandLineManager::AddParametersForConvertCommand: out_vm_name=Windows2012R2
1/10 13:44:21.940 1b50 Facility ???INFO: CCommandLineManager::AddParametersForConvertCommand: out_file_type=ft_vmdk_esx_thin
1/10 13:44:21.940 1b50 Facility ???INFO: MicrosoftFile::ParseFile: sFilename - [Datastore01] Windows2012R2_1/Windows2012R2_disk0.vhdx
1/10 13:44:21.940 1b50 Facility ???ERROR: MicrosoftFile::ParseFile: OpenVirtualDisk is fail - 3
1/10 13:44:21.940 1b50 Facility ???ERROR: RunConsole: Error create input image - 2
Tue Jan 11, 2022 4:52 am
Can you move the file to the Windows machine and convert it to VMDK as a local file? There is something on the network, the Converter cannot connect to the destination.
