First Timer Here, Unable to get Converter to go to Gen 2
TitanAlpha
Mon Dec 06, 2021 11:03 pm
I am converting from VMware 7.0 to Hyper-V 2019. No issues on either side but when i connect whether it be direct to the ESXi host or to vcenter, it only allows me to convert to Gen 1 in Hyper-V. Its probably something im doing wrong but i cant seem to figure it out. No issues and it converts with no errors to Gen 1 but of course since the BIOS is UEFI the VM wont boot.
Also per best practice the VM Hard disk and the VM Machine files are seperate for Hyper V but i dont have that option. Whats the behavior for these file placements via the tool?
Thank you so much!
Tue Dec 07, 2021 9:55 am
It appears to be a driver problem-related issue. Try converting the disk alone in the Repair mode. Also, having the error that prevents you from booting is appreciated.
See more at https://kb.vmware.com/s/article/1016192, https://communities.vmware.com/t5/VMwar ... d-p/453875, and https://www.youtube.com/watch?v=dQtUb91 ... ithPassion
