Error Read File - Convertation Failed
BottingS
Fri Oct 22, 2021 9:01 am
Hi
I have been trying to virtualise a Windows XP systems disk, because it has an important piece of software on it and the relevant data associated with it. It does not warrant its own computer.
The Host Drive is NTFS 1863.01 GB I am creating the VHD(x) on a separate drive 3726.01GB (I have tried it formatted as NTFS and xFAT and get the same error.
The Steps I take in the configuration are:
1) P2V
2) Disk Volume & Physical Disk (again both the same error)
3) For the Physical Disk I select the drive\Volume containing the 1836.01 (Windows XP) drive
4) The location - I select as a local file
5) Image format - VHD\VHDX
6) I have tried VHD and VHDx but both as a Pre-Allocated Image (due to the limitations of XP's Dive limitation to 2TB) - I have also ticked and un-ticked the repair mode box at the bottom..
7) Destination File - I select the disk containing the 3726.01 volume and name the VHD(x) file name.
8) I then select convert
It goes ahead and created the fixed sized VHD(x) file and appear to then start populating it, the software gets to 100% and then attempts to read the the file again when it then flags an error, below is the log file contents:
The log file name: 'logs\V2V_Log-20211021-090804.log' (PID 5244)
10/21 9:08:04.139 1abc Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
10/21 9:08:04.139 1abc Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
10/21 9:08:04.139 1abc Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
10/21 9:08:04.139 1abc Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
10/21 9:08:04.155 1abc Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19043
10/21 9:08:04.155 1abc Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 5f070000
10/21 9:08:25.206 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputFile
10/21 9:08:32.899 1abc Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
10/21 9:08:43.838 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
10/21 9:09:03.735 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelect
10/21 9:09:23.959 1abc Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eTypeP2V
10/21 9:09:27.486 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
10/21 9:10:03.908 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
10/21 9:10:15.721 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
10/21 9:10:24.647 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
10/21 9:11:27.764 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
10/21 9:12:25.591 1abc Facility ???INFO: CPPOutputFile::onNext: Out path: D:\SystemBoot.vhdx, Out format 11
10/21 9:12:25.591 1abc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
10/21 9:12:25.591 2764 Facility ???INFO: CPPConverting::Convert: InConvertType: 2, OutConvertType: 4
10/21 9:12:25.591 2764 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 2, pathOutput: D:\SystemBoot.vhdx
10/21 9:12:25.591 2764 Facility ???INFO: P2V::CreateInputImage: path 2
10/21 9:12:25.591 2764 Facility ???INFO: P2V::CreateInputImage: Size 2 - 2000398934016, BytesPerSector - 512
10/21 9:12:44.433 2764 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
10/21 9:12:44.433 2764 Facility ???INFO: MicrosoftFile::NewFile: sFilename - D:\SystemBoot.vhdx, nMaxSize - 3907029168, fileType - 2
10/21 12:55:49.648 2764 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
10/21 12:55:56.554 2764 Facility ???INFO: P2V::getSectorsNext: countClusters - 61047267, dwCountBytes - 61047266
10/21 12:55:57.929 2764 Facility ???WARNING: P2V::getBuffer: ReadFile - 23. Data error (cyclic redundancy check).
10/21 12:55:57.929 2764 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
10/21 13:03:16.650 2764 Facility ???ERROR: CPPConverting::Convert: FAILED
Your feedback would be much apprechiated :shock:
Fri Oct 22, 2021 11:19 am
Hi, try converting it to a remote machine that has more storage.
Kruppmityu
Sat Apr 01, 2023 5:59 am
Hi!
I got the same error message. I did an surface test with HDsentinel on the hard disk to be virtualized. It found bad sectors in the last few hundred megabytes of the disk.
I resized it with a partition management program so that the faulty part (plus a little more) is unallocated. After that StarWind was able to do the conversion.
Sun Apr 02, 2023 11:32 am
Cool, thanks for your update!
