Cannot create 3TB volume on HA disk
jdeshin
Tue Oct 05, 2021 3:40 pm
Hello All!
I've created a 3TB StarWind HA storage and successfully map it as a disk.
When I try to create volume on that storage by running New-Volume cmdlet then I give unexpected error after a long time.
Do you have any restrictions etc. for volume sizes?
Yury
Fri Oct 08, 2021 10:42 am
No, we do not have a limitation (we just recommend devices be below 7 TB to avoid full sync overlapping with backups or production workloads). The volume was created by StarWind VSAN. If you want to format it as NTFS, try diskpart as described here https://www.starwindsoftware.com/resour ... rver-2016/.
webdude
Sat Jun 11, 2022 2:06 pm
if I have a 15TB storage, do you recommend splitting it for multiple CSV? 7TB, 7TB, 1TB?
Sat Jun 11, 2022 4:51 pm
7TB, 7TB, 1TB?
You should. That will help to make full synchronization of your data discrete. This, in turn, should save you from re-synchronizing the entire array once again if synchronization fails. Still, if you have a large VM there, there is no need to push it hard.
Check the best practices out https://www.starwindsoftware.com/best-p ... practices/.
