Invalid Namespace (0x8004100e)
apicon
Tue Jul 13, 2021 4:42 pm
Hi Everybody!
I'm trying to convert an Entire PC to a VM, but in the Enter Microsoft Hyper V Server Connection Parameters page I got the error Invalid Namespace (0x8004100e) and I can't move from there.
A couple of things to take into consideration:
  • Software Version: StarWind V2V Converter (9.0.1.243)
  • OS from the PC that I'm doing the conversion: Windows 10 Pro
  • I already reinstalled the app, the same issue happens
  • I don't have logs due to the process get stuck in this step
With that said, can someone help me?
Tue Jul 13, 2021 8:47 pm
That can be related to non-ASCII symbols.
apicon
Wed Jul 14, 2021 1:43 pm
Hi Yaroslav
What do you mean?. The step where I'm stuck is this:
Wed Jul 14, 2021 2:26 pm
https://www.starwindsoftware.com/v2v-he ... erver.html
Please run it from a remote machine and type your hostname and password for that VM.
apicon
Wed Jul 14, 2021 7:16 pm
In this case, I'm running the converter from the PC that I want to convert to VM. Should I put in the credentials an admin account that is on this PC?.
Wed Jul 14, 2021 8:20 pm
You should be able to run conversion as localhost. Try converting it from another Windows VM/server.
apicon
Wed Jul 14, 2021 8:58 pm
That's the thing I run it from the same PC and put localhost (as the documentation says) but I got the error
Thu Jul 15, 2021 9:12 am
Please try converting remotely.
