Starwind VTL Free very slow performance
delmarth
Fri Jul 09, 2021 4:43 pm
I have VTL Free working with Veeam but the transfer speed never pass 2 MB/s.
Created an virtual disk in the same disk where VTL Tapes are located and mounted at Veeam Server, and could transfer files near 200 MB/s.
So the problem is on VTL. Is there anything to be bone to achieve higher transfer speeds?
Tue Feb 27, 2024 1:29 pm
We need to check your configuration to find a bottleneck. For now it's either network or for some reason source can't feed the data faster. Start with some network usage monitor on both client & server. Microsoft Network Monitor is old, but very usable still.
https://www.microsoft.com/en-us/downloa ... px?id=4865
asshley675
Thu Jul 04, 2024 5:40 am
Hello there :)
You should consider checking the network configuration between your VTL and Veeam server. Ensure that the network bandwidth is sufficient and that there are no network bottlenecks. Additionally, optimizing the VTL software settings and checking for any resource constraints on the VTL server itself could also help. Gathering more details about your setup would be beneficial in diagnosing the issue further.
Thu Jul 04, 2024 8:33 am
Thanks.
