ESXi 6.5 .vmdk to Hyper-V Error
Lord_Hypnos
Fri Jun 11, 2021 6:33 pm
I'm trying to convert and transfer my ESXi VM's over to a Hyper-V server. I keep getting these errors:
6/11 14:33:52.721 5304 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 1, Unknown error
6/11 14:33:52.721 5304 Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
I've tried: Gen 1, gen 2, VHD, VHDX; it consistently fails.
I'm using 9.0.1.243 along with running as Administrator and the VM is shut down. Any help would be fantastic!
Thank you :D
Sat Jun 12, 2021 8:04 am
Here user had a similar problem.
https://forums.starwindsoftware.com/vie ... ail#p32089
Save the file locally somewhere and try converting it then. Alternatively, convert the disk alone.
Lord_Hypnos
Mon Jun 14, 2021 12:35 pm
Thank you for the info! I'll give that a try.
Lord_Hypnos
Mon Jun 14, 2021 1:51 pm
It worked! Thank you for your assistance :D
Mon Jun 14, 2021 4:17 pm
That's amazing. Thank you for getting back to me!
