starwind free - device's not syncing
mathiasc
Mon May 31, 2021 11:14 am
i am migrating from HPE vsa to starwind free, and have setup 3 device's (volumes) :
- whitness
- vol1
- vol2
all device's are setup with the same script (i changed the volume names offcourse) but only the whitness (first created) is syncing, the others (vol1 and vol2) are NOT syncing and i can't get them to sync.
if i run the SyncHaDevice.ps1 i get following error:
Synchronize device HAImage3
Exception calling "Synchronize" with "2" argument(s): "Failed to perform synchronization (1) from
control 0x0000009CB9036480 -Synchronize: -SynchronizationType:"1"
200 Failed: can't find available or valid partner for synchronization.. "
if i do the same for the whitness device:
Device HAImage1 is synchronized
in the eventlog are no error's, he even says the synchronisation connection is established with the other partner but he just does not start synchronizing but only the whitness does start to synchronise ....
can anyone help?
the script i have created the volume's with:
param($addr="localhost", $port=3261, $user="root", $password="starwind",
	$addr2="plahv02", $port2=$port, $user2=$user, $password2=$password,
#common
	$initMethod="Clear",
	$size=150000,
	$sectorSize=4096,
	$failover=1,
#primary node
	$imagePath="My computer\F\starwind",
	$imageName="VOL02",
	$createImage=$true,
	$storageName="",
	$targetAlias="VOL02",
	$autoSynch=$true,
	$poolName="pool2",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="wb",
	$cacheSize=128,
	$syncInterface="#p2=10.0.100.20:3260",
	$hbInterface="#p2=192.168.0.154:3260",
	$createTarget=$true,
#secondary node
	$imagePath2="My computer\F\starwind",
	$imageName2="VOL02",
	$createImage2=$true,
	$storageName2="",
	$targetAlias2="VOL02",
	$autoSynch2=$true,
	$poolName2="pool2",
	$syncSessionCount2=1,
	$aluaOptimized2=$false,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=10.0.100.10:3260",
	$hbInterface2="#p1=192.168.0.160:3260",
	$createTarget2=$true
Import-Module StarWindX
try
	Enable-SWXLog
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
Mon May 31, 2021 12:25 pm
Welcome to StarWind Forum.
You need enough storage on both hosts while creating. Are you sure that you are having enough space there? See this post on CreateHA script.
https://forums.starwindsoftware.com/vie ... p+3#p31505
Also, just advice: create 1 GB devices first. Once full sync of the tiny device is over, extend the device - that saves you a lot of time.
