How to use a disk as iSCSI target (PowerShell)?
Rob864
Sat May 29, 2021 12:35 pm
Hi, I just started today with VSAN free and I'm trying to create an iSCSI target using a physically installed SATA HDD without using an image file. I need to do this in PowerShell.
I'm usually not afraid of PS but in this case, I just don't know where to start looking for the solution. I believe that none of the sample scripts apply in this case. I've been able to create a target using an image file with the sample script (CreateImageFile.ps1), no problem. But it isn't quite what I need. I would like to bring the disk online without an image file. What I could find in the help tells me that I want a raw device / disk bridge / SPTI setup. How can I do this with PowerShell?
Also, if there was a way to manage VSAN free with management console or web interface that would also work but I don't think that is included in the free version.
Any help would be appreciated!
Rob864
Sun May 30, 2021 8:56 pm
I've been able to resolve this issue, but now I'm having a new issue. But first things first. I've discovered that an SPTI device had been automatically created for each disk.
I query them with:
$server.Devices
They look like this:
Name                   : \\?\scsi#disk&ven_wdc&prod_wd30ezrx-00dc0b0#4&239d8b02&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
DeviceType             : SPTI:Disk
DeviceId               : 0x000001BF55B49040
File                   :
TargetName             : empty
TargetId               : empty
CacheMode              : empty
CacheSize              : empty
CacheBlockExpiryPeriod : empty
Exists                 : True
DeviceLUN              :
IsSnapshotsSupported   : False
Snapshots              :
SectorSize             :
State                  : 0
Parent                 :
Now I can create a new target with this device:
New-Target -server $server -alias $targetAlias -devices "\\?\scsi#disk&ven_wdc&prod_wd30ezrx-00dc0b0#4&239d8b02&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}"
This works. But the new target does not work properly. On the initiator side (Windows Server 2019), I can connect to the target, no problem, but the new disk behaves unexpectedly in device manager. Although the disk was pre-formated with NTFS, the new disk shows a raw partition. When I try to format this partition, format fails to complete. Which means that the target is unusable. Any ideas?
Tue Jun 01, 2021 4:47 pm
CreateImageFile.ps1 creates an image file that cannot be converted into the HA. Image file does not provide high availability.
For HA, use this script https://forums.starwindsoftware.com/vie ... p+3#p31505
Is there anything else I can assist you with?
nejir
Sat Jun 12, 2021 1:10 am
Rob864 wrote:Hi, I just started today with VSAN free and I'm trying to create an iSCSI target using a physically installed SATA HDD without using an image file. I need to do this in PowerShell.
One requirement for windows hosts to share one iScsi target is that they must be in a cluster. When you convert the volume to a CSV (clustered shared volume), the other nodes on the cluster will just see it and have access (assuming the general iScsi settings are correct)
If you manage to connect one ntfs volume to two hosts with iScsi outside of a cluster, the nodes will corrupt the data on the disk and you risk loosing everything. It looks like it works until you later discover you made a huge mistake.
Hi team, thanks for creating such an active forum.
Sat Jun 12, 2021 7:47 am
Yes you are totally right.
