Azure VMs are not listed
ITONNET
Wed May 05, 2021 11:24 am
Hi there,
I'm trying to convert an Azure VM to local VMWare.
I configured the Azure app as described in the StarWind V2V Converter Help.
I can choose the subscription but no Azure machines are listed. "Select a virtual machine or image" is emtpy.
This is the log file:
The log file name: 'logs\V2V_Log-20210505-131820.log' (PID 13720)
5/5 13:18:20.272 3a54 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
5/5 13:18:20.272 3a54 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
5/5 13:18:20.272 3a54 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
5/5 13:18:20.272 3a54 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
5/5 13:18:20.272 3a54 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
5/5 13:18:20.272 3a54 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 7a060000
5/5 13:18:23.866 3a54 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAzureConnection
5/5 13:18:52.413 3a54 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
5/5 13:18:54.116 3a54 Facility ???ERROR: TRY_CATCH: GetVirtualMachines - Unknown error
5/5 13:18:54.116 3a54 Facility ???ERROR: ICPPTree::fillTree: GetVMList fail - Error sending request to Azure.Unknown error
Best regards
Bernd
Thu May 06, 2021 4:11 am
Welcome to StarWind Forum.
Based on the logs, V2V cannot connect to Azure. Could you please double-check that you have set up storage account and app as described here https://www.starwindsoftware.com/v2v-help/Cloud.html.
ITONNET
Thu May 06, 2021 1:24 pm
Hi Yaroslav,
thank you for your help.
I removed all the stuff from azure and recreated everything based on the setup descibed in the link.
The issue is still the same. I already tried to install StarWind V2V on another clinet with the same result.
Bernd
Thu May 06, 2021 9:56 pm
Can you try converting the disks, please?
ITONNET
Fri May 07, 2021 7:54 pm
Hi Yaroslav,
I exported a VHD from Azure and I'm able to choose a virtual machine location in Azure and so on but convertation failed (see attachment).
5/7 21:30:38.381 3884 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
5/7 21:30:38.381 3884 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
5/7 21:30:38.396 3884 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
5/7 21:30:38.396 3884 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 7a060000
5/7 21:30:43.975 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputFile
5/7 21:30:46.599 3884 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
5/7 21:30:51.256 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
5/7 21:30:58.224 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
5/7 21:30:58.224 3884 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{42cb0dcd-4b48-482b-96dc-97c168f5e71b}\ fail - 87. Falscher Parameter.
5/7 21:31:04.881 3884 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eTypeP2V
5/7 21:31:09.412 3884 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
5/7 21:31:15.771 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputFile
5/7 21:31:25.802 3884 Facility ???INFO: CPPInputFile::checkFile: Select file: E:\BS.vhd
5/7 21:31:25.912 3884 Facility ???INFO: MicrosoftFile::ParseFile: sFilename - E:\BS.vhd
5/7 21:31:28.146 3884 Facility ???INFO: CPPInputFile::checkFile: ParseFile: 0
5/7 21:31:28.146 3884 Facility ???INFO: CPPInputFile::checkFile: File type: IDS_IMAGE_CONVERTER_FORMAT_NAME_VHD_FLAT File size: 209715200 sectors
5/7 21:31:29.959 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
5/7 21:31:35.740 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAzureConnectionTo
5/7 21:32:11.818 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputVM
5/7 21:32:13.661 3884 Facility ???ERROR: TRY_CATCH: GetVirtualMachines - Unknown error
5/7 21:32:13.661 3884 Facility ???ERROR: ICPPTree::fillTree: GetVMList fail - Error sending request to Azure.
Unknown error
5/7 21:32:16.958 3884 Facility ???ERROR: TRY_CATCH: GetVirtualMachines - Unknown error
5/7 21:32:16.958 3884 Facility ???ERROR: IConfigNewVM::IConfigNewVM: GetVMListInfo is fail - Error sending request to Azure.
Unknown error
5/7 21:34:02.021 3884 Facility ???INFO: ConfigNewAzureVM::GetConfigVM: Create new NI
5/7 21:34:02.037 3884 Facility ???WARNING: CPPOutputVM::OnButtonBrowseClick: Fill up GUID is fail
5/7 21:34:27.989 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eSelectFolder
5/7 21:34:29.505 3884 Facility ???ERROR: TRY_CATCH: GetKeys - Unknown error
5/7 21:34:29.505 3884 Facility ???ERROR: CPPSelectFolder::onActive: GetDatastoreInfo fail - Error sending request to Azure.
Unknown error
5/7 21:35:17.239 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
5/7 21:35:17.239 7c0 Facility ???INFO: CPPConverting::Convert: InConvertType: 4, OutConvertType: 9
5/7 21:35:17.239 7c0 Facility ???INFO: CPPConverting::ConvertImage: pathInput: E:\BS.vhd, pathOutput: https://diagnoseitonnet.blob.core.windo ... s01/BS.vhd
5/7 21:35:17.239 7c0 Facility ???INFO: MicrosoftFile::ParseFile: sFilename - E:\BS.vhd
5/7 21:35:17.239 7c0 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
5/7 21:35:18.598 7c0 Facility ???ERROR: TRY_CATCH: GetKeys - Unknown error
5/7 21:35:18.598 7c0 Facility ???ERROR: AzureDisk::CreateOutputImage: GetDatastoreListInfo is fail - Error sending request to Azure.
Unknown error
5/7 21:35:18.598 7c0 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 7
5/7 21:35:18.598 7c0 Facility ???ERROR: CPPConverting::Convert: FAILED
5/7 21:37:27.779 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocation
5/7 21:37:31.373 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAzureConnection
5/7 21:37:55.560 3884 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
5/7 21:37:57.154 3884 Facility ???ERROR: TRY_CATCH: GetVirtualMachines - Unknown error
5/7 21:37:57.154 3884 Facility ???ERROR: ICPPTree::fillTree: GetVMList fail - Error sending request to Azure.
Unknown error
Converting the VHD to ESX works fine...
Best regards
Bernd
VHD to Azure.PNG (10.77 KiB) Viewed 13156 times
Wed May 12, 2021 4:00 pm
Thank you for the update. Still analyzing the logs, will keep you posted!
Fri May 14, 2021 11:31 am
Does the group/host have non-ASCII symbols? Please contact us at support@starwind.com. Use this thread and 508058 as a reference.
Wed May 19, 2021 11:25 am
Will PM you with the build that has improved logging. Try to V2V and send me the new logs here, please.
ITONNET
Tue May 25, 2021 2:25 pm
there was a ressource group with german umlauts (non-ASCII symbols) that brought up the error.
I just moved the content to another Azure RG and the StarWind V2V Converter shows folders and machines on azure.
Thanks again Yaroslav!
Tue May 25, 2021 3:49 pm
Thanks for the update!
