You do not have access rights to this file
sis
Sun Mar 14, 2021 11:14 pm
I'm trying to do a V2V migration, ESXi 5.5 to HyperV 2019.
at 54% I'm getting "You do not have access rights to this file"
Here's the log:
The log file name: 'logs\V2V_Log-20210314-140439.log' (PID 15420)
3/14 14:04:39.512 2c98 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
3/14 14:04:39.512 2c98 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.0.202
3/14 14:04:39.512 2c98 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
3/14 14:04:39.512 2c98 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
3/14 14:04:39.512 2c98 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
3/14 14:04:39.512 2c98 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 18362
3/14 14:04:39.512 2c98 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 56ff0000
3/14 14:04:43.496 2c98 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
3/14 14:04:53.849 2c98 Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.120.5/sdk
3/14 14:04:54.005 2c98 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - df5296a3-2b0d-a10d-015c-2e74e03ad46e
3/14 14:04:54.021 2c98 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
3/14 14:04:54.302 2c98 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.5.0
3/14 14:04:59.987 2c98 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
3/14 14:05:03.373 2c98 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
3/14 14:05:10.074 2c98 Facility ???INFO: WrapperHyperV::connect: Host - \\rchost1\root\virtualization\v2
3/14 14:05:10.246 2c98 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsHyperV
3/14 14:05:25.632 2c98 Facility ???INFO: VMConverter::HyperVConverter::GetHostListInfo: HyperV version: 10.0.17763
3/14 14:05:25.632 2c98 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
3/14 14:05:25.647 21ec Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
3/14 14:05:25.866 21ec Facility ???INFO: WrapperHyperV::modify_cpu_and_memory: MaxCPU - 48
3/14 14:05:25.897 21ec Facility ???INFO: WrapperHyperV::getMaxMemory: MaxRAM - 190570
3/14 14:05:26.007 21ec Facility ???INFO: VMConverter::HyperVConverter::CreateVM: add_ethernet_connection is 1
3/14 14:05:26.007 21ec Facility ???INFO: CPPConverting::ConverterHyperV: Create VM 808F5D9D-CA68-44E5-8207-47B543BE2DFD
3/14 14:05:26.022 21ec Facility ???INFO: CPPConverting::ConvertImage: pathInput: [datastore1] DOCS/DOCS.vmdk, pathOutput: C:\HyperV\PaperVision\Virtual Hard Disks\DOCS.vhdx
3/14 14:05:26.241 21ec Facility ???INFO: ESXVmdk::ParseFile: sFilename - [datastore1] DOCS/DOCS.vmdk
3/14 14:05:26.241 21ec Facility ???INFO: ESXVmdk::ParseFile: m_cSSLThumbprint - 89:F1:79:BA:46:BD:59:43:F5:E1:FD:F9:27:95:43:16:33:B4:B2:89
3/14 14:05:26.241 21ec Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - [datastore1] DOCS/DOCS.vmx
3/14 14:05:27.926 21ec Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
3/14 14:05:30.621 21ec Facility ???INFO: MicrosoftFile::NewFile: sFilename - \\rchost1\C$\HyperV\PaperVision\Virtual Hard Disks\DOCS.vhdx, nMaxSize - 943718400, fileType - 1
3/14 14:05:30.715 21ec Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
3/14 16:12:22.652 21ec Facility ???ERROR: VMwareFile::Read: m_VixDiskLib_Read is fail - 13, You do not have access rights to this file
3/14 16:12:22.652 21ec Facility ???ERROR: CPPConverting::ConvertImage: Read 3
3/14 17:33:44.169 21ec Facility ???ERROR: CPPConverting::Convert: FAILED
3/14 17:34:17.901 2c98 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
3/14 17:34:17.902 2c98 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
TIA
Mon Mar 15, 2021 6:37 am
Make sure to turn off the VM.
sis
Mon Mar 15, 2021 11:00 am
The VM was off.
Tue Mar 16, 2021 4:34 am
Please try running conversion of a disk alone in the Repair Mode. Can you run the conversion from the VM on that server to the remote Hyper-V server?
Also, make sure to run the software as administrator.
